Do these mesh well?
Hey gang! Considering stereo work in my bimmer, tweeters in sails, 4" in door card, 9" under the front seat. I will have amplification and DSP. Do you think this would be a solid front stage? I have an Aura MR.18 IB for substage.
Tweeter - https://www.madisoundspeakerstore.com/soft-dome-tweeters-sb-acoustics/sb-acoustics-sb21rdcn-c000-4-ring-dome-tweeter-neodymium/
Mid - https://www.madisoundspeakerstore.com/approx-4-fullrange/scanspeak-discovery-10f/8414g-10-4-full-range/
Woofer - https://www.madisoundspeakerstore.com/approx-8-woofers/morel-caw938-9-woofer/
Thanks for any thoughts and recommendations.
  • The 10f has a very (VERY) neutral sound fwiw. You may consider the tc9 for a fraction of the price and a richer (sorry for the subjective word) sound.
    joeybutts
  • edited February 2023
    That’s the one. Personal opinion only; I have used both. TC9 was a better deal when it was $12.50, but still an overachiever in my book. There are better things out there I’m sure but I’d choose it over the 10f.
    Steve_Leejoeybutts
  • Well heck, that's a killer price for a wonderful mid. Appreciate the rec'!
  • +1 on the TC9. It's crazy good for the money and no slouch at any price.
    Steve_Leejoeybutts
  • Done deal.
    Where would you guys recommend crossing over the TC9 to the Morel 9”?
  • Of course a vehicle cabin is a whole different animal than a living room, but the 9” under a seat transitioning to a 3” in the door could be tricky. You will have to play around with it; my thought is 250-500ish, 250ish needing a steep filter. You will also probably have to play with the mid and maybe tweeter polarity.
    The benefit of a car (active) setup is electronic crossover and dsp/eq.
    6thplanetjoeybutts
  • What dynamo said. I'd be more inclined to go back to a 4" mid, something that'll be a bit better down low to blend with the underseat woofer.
    dynamo
  • I crossed the TC9 at 300 in the Hafnium and didn't have any issues with that. I agree that anything much lower than that would require a steep filter.
    joeybuttsSteve_Lee
  • Sounds almost perfect then if i am to cross the 9” around 150-200 to match up and not be located?
