InDIYana 2023...
24567
  • Oh, Ron E is coming? I believe it's your first time....
  • It is. A lot has to happen between now and then for it to actually happen. I'm trying to recover from the flu or cold so right now I don't feel like going anywhere.
  • Get well soon Ron! Looking forward to seeing/hearing what you bring for a theme project.
  • Hey Ben, can you put me down for a theme build - I am trying to make the theme criteria fit, if it doesn't it will be a non theme. will be getting only one pair of speakers.
  • Theme build for me also, I'll come up with something
  • One non-theme build for me. First time since attending :/
  • edited January 2023
    I will have 2 non theme, 1 theme (possibly)
  • Put me down for 1 theme and 1 non-theme pair. :)
  • Getting the OK from work now and will clear it with the wife tonight.
    Planning on bringing a theme entry.. if I get my butt in gear and start on it.
    I could bring a non-theme entry, but It is sounding like that might fill first. I doubt you all would want to listen to my junk anyway :p
    Bring it. We have plenty of time on Fri to listen to
  • I think Craig and I should be there by noon or so.
  • Ok looks like I'm on the list so no need to email I suppose. Just need to pick which non theme build would be best/most palatable.
    Sounds like my wife may come too. Figured she would be bored, but she wants to be supportive which is pretty cool! Guess that means I have to get working on her craft room between working on the theme build.
  • I did not see this mentioned anywhere (maybe I missed it), but are Isobarik woofers allowed?
    As long as you are under 1 5 cu ft gross, and use at least an 8" woofer, yes!
    If not, we can file a formal protest together, since that is my plan too! 🤣 It IS just a passive two-way so I can't see how it would violate any of the rules.
    (I'm pretty sure the Inbox for formal protests is Ben's waste basket)
  • Isobaric is fine, or I would have told Bill earlier. It files under the multiple woofer allowance.
  • Hello Wolf, Barring any international boarder problems, I would like to attend with one theme entry. Thank you, David.
  • The crown amp you guys use is a class-D isn't it? Does it do Ok on speakers with big impedance swings?
    It's never had an issue with any speaker we've put it on.
  • Figured so, just thought I'd check. Thanks
  • Hmmm.... this is a good possibility....
  • edited February 2023
    It seemed like in the past folks would bring stuff to sell off/get rid of? I need to shrink down my shelf-o-drivers. Gauging interest if it is even worth it to lug out there.
    Stuff I've opened to verify no coil rub but otherwise unused, would let go for cheap:
    2x Goldwood GW-1238/PA - guitar/instrument 12s.
    4x Celestion T5744A SP-1500 - 15s I got to experiment in dipole/OB but never got around to it.
    And some other bargain bin PA style drivers I've tinkered with that I'd probably just give away.
    We will have a "for sale" area
  • There is usually a pretty big selection of "for sale" and "for free" stuff. Just bare in mind that DIY'rs are generally tight wads and won't buy something unless it's crazy cheap :p
  • Wolf,
    How high are the speaker stands at InDIYana?
    Wondering if the tweeter on a 23" tall "stand mounted" speaker would be too high?
    Thank you,
    David.
  • Someone’s cardboard game is on point.😉
    Wanted to see how odd a 1.5 cubic foot box looked on a stand before I built it.
    Turns out, not to bad! :)
    Would have gone with floor standing if this didn't look right.
  • I will have a pair of stout crates that can be used at 3 heights, in addition to the 22" stands.
  • I'm working on a pr of 16 to 18" stands in addition to my normal 24" stands that I bring
  • Friday 31st is last day to reserve room under the discount block.
