Monster project. Wanted to share
I had 28 of these laying around. They are motorcycle audio speakers. Nothing special!Built 4 identical boxes to hold 3 woofers and 1 mid. The tweeter enclosure in the center will hold the crossovers inside on a slide drawer. The woofersare in 4 cu.ft tuned to 44hz. The midrange is in a .5cu.ft sealed wedge enclosure. The diffuser panels surround the mid 5” back from there 1.5” denim than behind that stuffed with poly fill. Checking my progress with xsim. Still some work to do but the soundstage on these is getting very detailed. Do you think it’s the way the drivers are shaped?I used the Peerless DA25TX 1” tweeters crossed at around 2.2k and mids crossed around 150hz. Trying to use minimal components. Roller feet in the future and some type of finish probably not a high shine finish, that sounds time consuming. I have under $500 so far in them. When finished I would like to be at around $1k.
jhollanderjr@macGowakennykBryan@MACD1PP1NS7910DanPSteve_LeeColonel7and 4 others.
