Cause of this
This is an impedence sweep of my most current effort. What is the most likely cause of the perterbations at 250 and 500?
  • Cabinet panel resonance at 500, the 250 might be as well, but also possibly because it's ported but trying to act like a transmission line at the same time.
    R-Carpenter
    Good catch JR - if it's port or cabinet standing wave resonance, Hornresp will show that.
  • You could plug the port and run the sweep again.
    Wolfrjj45
  • I'm setting up again this weekend and will check it out.
