Winter plans
1235
  • I'm getting more done on the table. Still need to wire the outlets and switch.
    jr@macS7910
  • Oh and this. 2 more panels to do. Then routing, veneer, and wiring. Next weekend????
  • Nice setup Chuck. Its really gonna help with the amount of builds you do. Is that a circular saw in there or you build it over the tablesaw? I want to make a router table with 2 or 3 inserts so i can just have like a flush trim and 45 and a round over always in them lol. Its lazy but i bet would speed up work flow quite a bit.
  • Thanks Mike. That is an old skil circular saw. The steel base is bent. I removed the blade guard. Its square though. I will be using T tracks to make a fence for it and the router soon.
  • Man... I've got more projects going on "than you can shake a stick at" (my Grandma's saying).  I think I need to take a step back and formulate a plan of what gets worked on first, second, third, etc so I can actually finish stuff.  The big tube SET amp is working... sounding so great that I find myself not motivated to actually finish it (bottom protective cover, pretty feet and volume knob).  I have several speaker projects started....  arg
  • Am I the only one with DIY ADD?
  • Oh heavens no! Im juggling 4 projects in the shop, building the table, getting ready for a coupleof summer projects, and a few customers as well.
    Im going to need a vacation from my vacation!
    Nope not at all. Im super good at starting shit and finishing 75-90% of it then losing interest and never wanting to touch it again.
  • Yeah, I got too much cutting done in November and now feeling swamped with almost everything in a state of incompletion. I need to take 1 and run for the goal line.
  • Holy shit, made some headway today on Nick's all-German driver project. I have been busy as hell this winter with work (and due to get even busier in the next several weeks), so due to a Dropkick Murphy show last night and the kid having a presentation early this afternoon I took the day off and made a huge mess in the living room and the nerdery and did some extensive voicing of Nick's speaker.
    He can chime in with driver details, but it is a Eton midwoofer and a LPG tweeter. The tweeter is a pain in the dick to use, been awhile since I have had to bang my head against the wall like this, but I beat that bitch down.
    There are eight components on the tweeter. A series resistor, a series cap, a shunted coil, a resonance trap for the tweeters impedance peak, and a flattening circuit to tilt the top end down. What you do not see in the above measurement is a natural hump in the tweeters response right in the 10k region which made a lot of ssss ssssss sssssssssibilance.
    Nick, if you are reading this, you might want to consider not using a toob amp to drive them. The impedance is a bit swingy. They sound totally decent, though. We can connect offline and discuss the next steps - I can probably build you a crossover with surplus shit I have on-hand and save you a bundle if you are interested.
  • These cabinets have been a bit of work. I hope to be in a position to mount the drivers and do some measurements this week.
    Turn2kennykSilver1omojhollanderThumperTom
  • That's an interesting cabinet. The wood look layered, is it bamboo?
  • It's 3/8" Baltic birch glued to cork flooring which has a layer of cork on both sides of a composite core. The sandwich is roughly 3/4 inch thick.  Each panel was veneered with quartered cherry and trimmed with cherry hardwood. Each panel had the edge mitered at 45 degrees and then the box was glued together. You can see all the 45 degree joints come together in the picture of the corner. Like I said it was a lot of work. There are 48 separate pieces of hardwood.
  • Should I?
    kennykS7910
  • If you must. But I hope this means you've shifted to 3-way mode.
    OTOH, there's only 3 weeks of winter left. Time for a Spring thread soon?
    You are correct, sir - however, winter can last through early April in Sioux Falls sometimes.
    I have found myself rolling more and more 3-ways these days. There are several reasons - not the least being you can generally perform equal to or better than a 2-way with the same budget.
  • Not the way this winter is going!!!
  • jr@mac said:
    Should I?
    I used a pair of those 4" mids back in the early 80's in the doors of my 72 Super Beetle.  Wrong driver for the task.
  • I like that yours still has the ratshack price tag on them.  $9.95 was a pretty good deal back then considering a ski resort lift ticket in the midwest was around $20/day.
  • Crossover for the MCM 3-way. I had the big Dayton caps sitting around, so why not? I might solder them up when I get home from work today - see how it goes.
  • Winter is almost over and so are these.  I finished up the crossover sims last night and ordered the parts. I'm going to get some black #4 screws for the tweeters. All Dayton with Nd105-8, CE65W-8 and PTMini-6.
    D1PP1Nkennyksquamishdroc4thtrygreywarden
  • Interesting.  I always wondered about that CE65.
  • Ron, for MWAF?
  • edited March 2017
    Ron, do have any measurement on the CE65W-8 ? There's nothing on PE.
  • Kenny, I'd like to take them to MWAF.  They're a gift and I'd have to borrow them and I need to figure out if I'll have the finances to get there this year. They could definitely make it to DIY Iowa.  This it the CE65W-8 1 meter measurement with the mic on the lower end of the tweeter axis. The rear camber is made from a 3" mailing tube that's about 7"'s long. I lined the front part of the tube with a piece of cotton towel and filled the rear with cotton insulation.  I'm using it from 2k to 5K 24db/oct.
    Midrange Sim
    kennyk
  • Looks matter - this red 3-way will have almost all red components in the crossover. All Audyn caps (and there are a lot of them) and all Dayton 18awg coils (and there are a lot of them).
    That little 3" MCM is nice enough, but I will never use it again. It proved to be as problematic as the Dayton PS95 (in fact, the two are almost identical as regards linear distortion) and there is a peak in the response (visible in the Dayton published data, incidentally) that required the notch filter on the mid circuit. That leaves me with very little sensitivity to sacrifice.
    Anyways, heres to swimmin with bow legged women and crimson crossovers in crimson cabinets.
    xo.jpg 67.8K
    kennyksquamishdroc
  • Thx Ron. <3
  • Well, the parts are still in-transit (the price you pay for 'free' shipping I suppose, so it will be next week before it is all done.
    In the meantime, the wife and I have this on Thursday:
    Saturday night we are staying in the hotel at the Grand Falls Casino - we need a night out, the two of us.
    Friday night we have something going on, as well.
    So, i am closing the chapter on winter plans - and will create a thread detailing the 3-way build and shelf it until DDIY so I can finish up one other build before then.
    kennyksquamishdroc
    I had to drill out the screw holes to get the #4s to fit
  • I bought #3 sheet metal screws with phillips pan heads and will paint them black.
