Insomnia has its advantages...
2
  • edited August 2022
    Great write up JR. I wish I had your writing talent.
  • With that nice sensitivity, there might be a few SET tube guys that would love them.
    It isn't super sensitive. My FR measurements are done after I measure for distortion at 95db. I just gate the distortion measurement. I like to know what is going on in the on-axis at high volumes. So, probably a bit more than 1W represented. If I were to hazard a guess, I would say it is probably around the 81-82db range and that is only because I didn't do a full baffle step. It is kind of why I recommend a high current Class AB or a cheap high output Class D for them. They will be power hungry, but that is the price of hitting below 50Hz in a sealed design in only 1.2 cubic feet.
  • I'll build stands for them tomorrow. I'm going to run them as my mains in the basement for awhile.
    I've always had a knack for it - I give credit to the thousands of books I have read.
    Updated and expanded writeup attached.
  • FYI, the unofficial name for these speakers is "Insomniacs".
  • ugly_wooferhifisiderjj45
  • JR, did you model this as a ported floor stander?
  • It ports pretty poorly. I know Rory did so with his Iguanas but he must have used some magic or a very low crossover point.
  • JR, did you ever get any glamor shots of these completed on the stands? This does look like a fun build. I hope to hear them someday.
    I totally forgot to do so lol. I get some time I'll pull them out and do so.
  • No worries. I bet I have 80% of what's needed in my stash of unused drivers. I should just stop being lazy and build them.
    Pretty straightforward build with a simple xo.
  • I found I had near half the parts already so I ordered the rest a while ago. Gotta start finding homes for builds though before doing more. If only I could break this habit of building big.
    jr@macSteve_Lee
    Big or small, I can't seem to stop building as well.
  • Small just has different challenges.
  • A friend of my wife expressed some interest in me building something for them. I don't trust my own skills enough to design something for a non family member. But I have the parts for this.
    They seemed open to towers if they aren't huge. Was thinking of narrowing the baffle an inch or so, but keeping the M/T the same distance from the closer side. I wouldn't think that would effect baffle step enough to add more than a small midbass dip all else being the same? Woofer Qts seems would make for little change in the bass alignment with a not huge increase of internal volume.
    Gotta wait for the 8"ers to come back in stock. One ended up being a dud measured 10ohm :o
    jr@macSteve_Lee
  • Yeah, an inch wont matter much. You could probably get away with 1.75 cubic feet and it would be pretty good.
  • edited July 2023
    Cool, only other thing I can think of would be: Any idea how much recessing the woofer ~1/8" would mess up the alignment? These will probably operate most of the time with grills. Not wanting to screw up the sound too much I thought of trying thin 1/8" tempered hardboard stuff. But the woofer gasket and surround would probably be thicker than the grill in that case.
  • That won't dick with things too much, either.
  • Looks like the DSN25F-4 is discontinued :/
  • Bummer, I liked those little boogers...
  • Guess I'll have to try a different tweeter. The ND28 would be a natural but the reports of consistency issues scare me off.
  • edited August 2024
    Any experience with the ND25?
    Nope, although that is on the list.
    I did get a pair of ND28's that were mismatched but PE was kind enough to send me two more for free. In the end I had two that matched very well. They will be playing in Iowa paired the MAC-04 woofers.
  • Used the ND25 in the Synchaetas, I liked them. Good to 2.5K, but sounded better above 4k.
    I think you guys figured it out, but I meant the ND25FA to be specific. I forgot the waveguide one is also an ND25. (and Ti, and no faceplate version, doh)
  • Nothing wrong with the ND25FA. (Nevermind the chalkboard black baffles. That mistake is being corrected.)
    cid:042506B4-0319-4F9B-82AA-AD8254E205FC
    jr@mac6thplanetkenrhodesDrewsBrewsPWRRYDSteve_Leehifiside
