Ooooh! New XO/DSP Unit coming soon . . .
This looks like the ticket --> https://www.minidsp.com/products/minidsp-in-a-box/minidsp-flex-eight
Just wish there was a compact multi-channel amp to go with it.
  • edited August 2022
    How compact or affordable?
    I think the Topping PA5 looks as good as any other amp around $350 per 2 channels; although a bit limited in power. (80W/4ohms)
  • Hey TK - that ^ thing is only a 2 channel stereo amp - I am suggesting a 6 channel amp - 6 powered-outs for discrete drivers . . .
    I have two of these on-hand waiting for me to build a chassis but keep holding-off due to lack of a good enclosure --> https://store.sure-electronics.com/product/613
  • Has anyone tried this chassis? --> https://www.circuitspecialists.com/rackmount-enclosure-et235b.html
    Needs more ventilations for those ^ amps I think . . .
    I haven’t seen any measurements of the Wondom modules.
    The only DIY amps I have assembled since I stopped using class A/B have been Hypex UcD and nCore.
    Buckeye Amps now assemble complete 2-8 channel amplifiers, that’s probably what I would recommend if I didnt want to build.
    BrannigansLaw
    Look at the link I posted above and on the left you will see a menu with SPECS and PERFORMANCE data, TK - Let me know your thoughts.
    I selected these overpowered (200 WPC) Class-D amps as I will not run them at high levels which should keep distortion-low . . .
  • The specs looks ok l couldn’t comment apart from what is published.
    It’d be nice to see measurement from an independent third party.
