Introducing: Retro Speako
1468910
  • Thanks, dcibel!  I really appreciate you taking the time to test this for me.  I have really learned alot in the past few days by  reading (and re-reading) your detailed posts.
    So, if I am understanding you correctly, basically what it comes down to is that the small to medium time alignment errors that I am measuring in the forward facing hemisphere will have little to no impact on VituixCAD's power response or DI curves.   By time correcting OmniMic's off-axis FRD's, I can accurately model on-axis as well as any individual forward facing off-axis angle,  but I cannot accurately model power response, DI, or listening window information.  To do that properly, I need a 2 channel microphone setup that can accurately measure the rear facing hemisphere as well.
       On the positive side, this seems much better than what I was previously doing in XSim.  In XSim, I could only model on-axis and perhaps two or three polar angles (like 45H and + or - 10V).   Doing more than this was much too difficult, as I would have to quickly flip driver icons back & forth on the schematic screen as I tweaked the xover.  Not a very good system at all.   In VituixCAD, I can at least watch both on and off axis curves update instantly as I spin or optimize xover part values.  That aspect alone is a real improvement for me.   Can't wait to get my 2 channel system set up and running! Thanks again! :)
  • I installed a couple internal braces to dampen the side panels:
    I routed 4 small donuts from the curly maple woofer cut outs. I didn't cut all the way through with the router. Instead, I left about 1/8" of material and finished the donut cut outs with a small hand saw.
    I then silicone glued two of the donuts to the internal ends of my bass reflex port tubes:
    After the glue set for a few days, I rounded over the donuts to produce curly maple flares. I gave the curly maple flares several coats of Arm-R-Seal and then silicone glued the ports in place using the other two donuts as mounting flanges.
  • You know you've got an issue when your inside parts, are as pretty as the outside parts.
    4thtryrjj45
  • I sealed up all interior surfaces with Arm-R-Seal as well. Trying to slow down the rate at which the wood picks up or releases moisture.
  • @Nicholas_23 said:
    I wonder if satin or gloss helps with the grain popping unsanded . You have voids in the grain, then fill it with a satin/gloss and get a 3D holographic view when finished and dried. Bounces the light around a bit if you will. Really sharp! Im curious when and how you do the woofers.
    @Nicholas_23 -- I finally got around to re-foaming and re-sizing the cone to replace the woofer that I had botched up a while back. So, here are a few photos of the process.
    First off, I cut the cone down by about 1 inch with a hobby knife:
    Rear of woofer showing the backside of the downsized cone:
    Test fit of new foam surround and 1/4" masonite ring adapter. I used the PE #260-955 Advent refoaming kit.
    First, I glued the new foam surround to the 1/4" masonite ring, being very careful not to de-form the circular shape of the new surround.
    Then, I glued the inner edge of the new foam surround to the cone, allowing the 1/4" masonite ring to float free or loose (very important):
    After allowing the glue to dry several hours, I lifted the 1/4" masonite ring up by about 1/2 inch or so and held it in place with a standard #2 pencil on each side:
    I then ran a bead of black 100" silicone cement under the ring and along the sides. When I pulled out the pencils, the masonite ring pressed into the silicone cement. The new foam surround self centered the masonite ring as the silicone cured.
    To finish up, I removed the temporary alignment shims and glued a new dusk cap in place. Done.
    The finished woofer sounds OK, with an Fs of about 22Hz and Qts of .34. The higher frequencies in the 500-1000Hz region are not a perfect match, but overall efficiency and alignment of the two woofers is roughly the same. One take away is that you need to be very careful to use the same amount of glue on the cone and dust cap as this can affect the high frequency performance quite a bit.
    jhollander6thplanetrjj45
  • I built a pair of matching hardwood stands.   They are 9 inches high and use the same mahogany + maple pattern as the main cabinets.   To improve the visuals, I angled the stands 17 degrees to create a "launching pad" type profile.
    Silver1omougly_woofer6thplanetTurn2rjj45Ron_EBryan@MACNicholas_23squamishdroc
  • edited February 2022
    Those look really nice Bill! Can't wait to hear them.
  • Yes - very cool! You now have the perfect spot for some mono blocks. ;)
    ugly_woofer4thtry
  • Kinda has a lava lamp feel now👍🏻 Looking good dude!
    ugly_woofer4thtry
  • A true artist! Wowzer
  • Thanks, guys.  I plan to demo these at InDIYana in May.  I should have the crossovers done by then.   If you can make it, stop by and give them a listen. :)
    Billet
  • Next up:  Dual channel spinorama and VituixCAD modeling.  Will post detailed screenshots as I go along. I have been reviewing the various spinorama pdf's and Erin's Audio Corner reviews in an effort to develop a better understanding of the various curves.
  • Amazing work and a version of Pythagoras in hell . . .
    Will you be placing the Xovers in the new stands you built?
    I was thinking about that. But too late. I have already cut recessed holes for the input cups. Lots of empty space, though. I could easily bolt a plate amp under each one for bi-amping. B)
  • If you built a front panel for the lower compartment, you could put a small sand bag or two in each one for ballast plus damping. This may or may not benefit the bass response, but it certainly has potential...
    Speaking of damping, I bought a Flexgard 1/4" thick rubber utility mat on sale today. $29 for a 36x60" roll. Very dense rubber, has the look and feel of the rubber used on automobile tires. I glued a small test piece of the rubber to a small block of mahogany to see how it sticks to wood using 100% silicone sealer. Sometimes silicone does not stick well to foam rubber material, but this is very dense rubber and may work better. What would be the best type of glue to use to glue rubber to wood? I am thinking of cutting small 6x8" or 8x10" pieces of this rubber and gluing it to the interior enclosure walls at various spots to dampen resonances. As I tap along the enclosure surfaces, many areas go Boooonnnngggg with a slow decay.
  • Contact cement.
  • Contact cement is good idea I think.
    The enclosure will bong less with drivers and stuffing, any stuffing at all, it doesn't need to be directly fastened to the panels, because the majority of that long decay is just the waves bouncing around in the open unrestricted space. Close it up with a pillow stuffed in one, leave the other cabinet empty and compare, the difference is not subtle.
    4thtryBillet
  • Contact cement for the win! Put some stuffing in the box and re-tapped. You are correct, makes a huge difference in the bong. :)
    dcibel
    I can provide a little insight on the "spinorama" for design. Simply put, the set of responses here are each progressively including more and more of the off-axis data as you move down the list from on-axis, listening window, early reflections, in-room, sound power. DI is a comparison of either on-axis or listening window to the sound power response depending on the option selected (listening window by default). The combination of all these plots provides rather detailed insight into the combined overall effect of driver size, separation, cabinet shape, and crossover without having to interrogate each off-axis response individually.
    I personally don't pay much attention to the ER and ERDI for crossover optimization, can really turn those guys off to reduce the clutter.
    I set a my optimization targets by listening window and in-room response. Set listening window target on the SPL chart at -0.2dB/oct from 100Hz to 10kHz. Set the in-room target on the power & DI chart at -0.8dB/oct from 100Hz to 10kHz, or a similar slope that should draw a nice trend line through the in-room plot. Then optimize the overall response by listening window and in-room response at 50/50 weight.
  • Thanks for the target line suggestions. I will be doing this shortly. It took me a while to get everything set up, but I finally completed the full set of dual channel spinorama measurements on this speaker. Total of 39 measurements; 13 for tweeter, 13 for mid, and 13 for woofer (0,15,30,45,60,75,90,105,120,135,150,165,&180). Microphone distance was 39" on axis to the driver for all measurements. Microphone distance to the floor was 72.5" for the set of 13 tweeter measurements; 66.9" to the floor for the set of 13 midrange measurements, and 54.5" to the floor for the set of 13 woofer measurements. The vaulted ceiling distances were even higher. So I should be able to get a reflection free gate close to 5ms or so.
    I created a zipped up folder with all FF measurements, woofer NF measurements, in box zma files, and dimensional drawing in case anyone is interested in looking at the raw IR files. It is about 75 megs, so I cannot post it here. Using VituixCAD's "Convert IR to FR" tool, I also created a zipped up folder of the same files in FRD format. It is only about 600K, but the FRD's have my microphone calibration file and gating decisions baked in.
  • Can you plunk them on google drive or one of the many other popular cloud storage services?
  • Checking into setting up an account.
  • edited August 2023
    I loaded the raw Soundeasy IR files into VituixCAD's "Convert IR to FR" and then re-saved them as single column mlssa.txt formatted IR files. This eliminated the redundant data column and reduced the zip file size by 40%.
    EDIT: Large attachment removed to conserve server space.
  • Great, first glance they all look like perfectly good measurements. Use of a dome midrange is putting the impulse peak at the same time location, so they are "time aligned". Midrange response is a bit unfortunate but I think you still have some useful bandwidth there to make it work.
  • I've generated my first model using the spinorama data set. Here are a few screen shots of the process:
    Initially, I loaded the raw IR files into the Converter tool and set the gate for all files to 4.8ms. Then I used the "feed speaker" check box to automatically load the resulting frd files into the various driver frequency response tabs.
  • I then created a diffraction model for the woofer and merged it with the NF and FF woofer data using the merger tool. I did not attempt to include floor boundary reflections or reinforcement in the model, so flat response will result in the full 6dB of BSC applied. Since my woofers will be 17" above the floor using my 9 inch stands, I will be attempting to depress the 50-200Hz area by 2dB to compensate.
  • Here is the 6 pack screen and reverse null. 16 parts. Note that the 80-200Hz area is slighly depressed in the model to account for the woofer to floor distance of 17 inches.
    Reverse null:
    ScottS
    Nothing inherently wrong with what you show in the screenshot, the results will work perfectly well, but you appear to be skipping over a lot of the convenience features of the IR tool here just to keep consistent with the process of other applications. Of course, more info in that measurement instruction doc for VCAD bla bla no one ever seems to read it.
    Below is just some tips and tricks to make life easier for next time.
    All you really have to do in this window is leave the left window enabled as it was by default. Select the tweeter 0 deg response, hit "FAR 1" to automatically set the window start to the impulse peak, then simply adjust the right window length as needed and save your files. If processing midrange and woofer files seperately, DO NOT press the FAR 1 button again, only once for the tweeter and then be sure not to adjust the reference start time
    Using the impulse peak for window reference is not a problem, as long as there is a "left window" as well. If other measurements happen to place the impulse behind the reference time, it's not a problem as long as they are not off by more than the left window, generally 1.5ms is plenty. Following this method gets the phase response a lot closer to "min phase" so there isn't a lot of excess phase wrap, and the phase plots in the main window will be easier to view overall.
    For the near field responses, simply load them up and hit the "near" button, and save.
    VituixCAD started showing the impulse dBFS and ETC instead of the raw amplitude by default as well, with the idea that its easier to determine the reflections without having to zoom in on small blips.
  • Bill, you're at 2.5 ohms at 2k. I'd be leery of that.
