Magical liquid + magic powder / Chemical reaction of CA glue and saw dust
  • That appears to be about 500% better than my old white glue/sawdust paste routine. Certainly faster.
  • Be cautious. The CA glue soaks into the wood and seals it. This will affect the look of the final product. For this reason I will often used the thicker CA glues, it still soaks in just not as much. I also use 5min epoxy to make filler. The epoxy can fill some LARGE voids, and stays stable.
  • That's crazy...........glue.
    Silver1omo
  • I’ve done crude patches with sawdust and wood glue and it’s pretty solid. I’d never rely on the same for a corner or edge repair. I wonder how solid that is. God knows I’ve fucked up many edges, corners, etc.
    My signature goes here
    I see what you did there
  • I tried this method over the weekend with medium CA glue. Didn't work any better or even as well as my white glue method. I'll try it again next time I get some thin CA which i don't normally purchase.
    dcibelrjj454thtry
