At Menards today and this caught my eye:
Normally I block sand using 1/3 sheets adhesive backed and a block of MDF. This is probably better.
It was about $10, and the hook and loop 1/3 sheets are about $1/ea. Not too bad imo.
Anyways, all done DIY'ing today, time for beer.
How rigid is that sanding block? It looks a ton more egronomic than what I do (same as you use to do).
The edges (1/2" all around) are fairly compliant. The remainder is solid. The body is what I would consider medium density foam. Fits the hand well.
I'll give Menards a look tomorrow for that.
My favorite general purpose sanding block is called prepping weapon, and it's actually for body work, but the velcro backed paper looks convenient.
This was worth every cent. I spent hundreds and hundreds of hours helping my old man block sand cars - this thing is badass.
Hmmmm...
I bought this a couple weeks ago, and just got a chance to try it. All I can say is that I should have bought one years ago. I have always used wet diamond stones but this is so fast that I won't put off sharpening chisels and plane irons ever again. It also did a fantastic job on some scissors and knives.
Did you look at the Grizzly version?
I did look at the Grizzly version as well as the Jet version, but both had mixed reviews and reports of grinding wheel wobble. In contemplating which to buy, I decided on the Tormek, because sharpeners are all they make, and I generally don't care about the warranty, but I like that they have enough confidence in their product to guarantee it for eight years. So yes I spent a good bit of money, but I will probably never have to buy another one.
Tormek is very good. I've had it in the shop for a few years.
