Small high end 2-way
123457»
  • @kenrhodes said:
    There were times I wished we did not share names... TBH not many call me Kenny.
    But many people call KennyK, Kenny.
  • I wasn't sure if that is who was being referred to.
  • Yeah, generally yes. You are Ken, and a wonderful Ken you are!
  • Finally getting shipped off for a xover!
    jr@macsquamishdrocSilver1omoPWRRYD
  • Please replacethe woofer screws with black
    oxide screws :s Otherwise very nice looking project.
    joeybuttsrjj456thplanetkennyk
    They will be, only fitting screws I had at the moment. 🤣
    Thanks!
  • Hope this crossover guy is better than the last...
    joeybuttsPWRRYD
    As long as it sounds good, got plenty of time😊😊
  • ...at least they aren't cardinal mounted. ;)
  • That means surface mounted, correct?
    Means the drivers screws are at 0, 90, 180, and 270 deg. I also prefer the way you mounted yours and always do with 4 screw drivers. When it comes to drivers with 6 screws it depends on whether they have truncated frames and if I want to use the narrower profile for a narrower baffle width. With 8 screw drivers I still prefer the way you mounted yours, not having a screw right at the top and bottom. I have seen diy guys and commercial speakers done both ways so I guess it's personal preference...
    joeybutts
  • Eww..... Yes, I always mount at 45's for 4 screw unless for some reason forced not. Something visually weird to me with screws on the vertical midline.
  • 5 screws???
  • Got it back and two xovers to try, gonna order parts this week and hopefully have it up and running by the end of the month! The enclosure is a bit small for the woofers on paper but my size constraint was specific, we'll see how the extension goes, but hopefully everything else is smooth and pleasing.
