Test instruments and rigs - share them here!
2
  • I used to build Heathkit test equipment. The scope died a long time ago but I still have the voltmeter and audio generator. The voltmeter is currently dead but I still use the generator. I still have the manuals so I may trouble shoot the voltmeter
    dcibelSilver1omo4thtry
  • Lots of vintage gear here, I recommend checking out a youtube channel "The Museum of Everything Else", some cool stuff in there if you're into pre-computer age electronics and synthesizers.
    https://www.youtube.com/c/THEMUSEUMOFEVERYTHINGELSE/videos
    If you're really into analog synthesizers, this guy's main channel is "Look mum no computer". Lots of cool stuff in there.
  • Those Heathkits tug at my heart! They got me started in electronics: in Jr. High I built a Heathkit VTVM (Vacuum Tube Voltmeter) and a shortwave receiver.
  • Ron - very cool! I have fond memories of using that same signal generator in high school. I also remember using the HV power supplies that shared the same case.
    Ron, Is that the IG-18? In 1971, there was a modification article in Audio Amateur Mag on significantly improving the distortion and meter accuracy of the IG-18. Bill
  • Finally got around to restoring my Heathkit TT-1a tube tester. This was Heathkit's flagship mutual conductance tester, which they sold from roughly 1960 to 1973. Before powering up, I tested all caps for leakage and measured all resistors against the schematic. All caps still measure good with no visible signs of leakage or bulging. A few of the 1% precision resistors were slightly out of spec, but not too bad (2-3% or so). All diodes checked OK, so I powered the unit up very slowly with a current limiting variac. I did this in stages to protect the transformer and to give the old electrolytic caps plenty of time to re-form. No smoke or strange smells.
    I then went through the complete step by step assembly manual testing and calibration procedure. Everything checked out good! No wiring errors found. And I was able to set all adjustment pots fairly close to the middle of their ranges, which is a very good sign.
    In the next few weeks, I plan to order all new electrolyics, film caps, close tolerance resistors, and diodes. Should be about $50 or so from Mouser. After installing the parts, I will have to go through the entire testing and calibration process again. As a backstop, I kept a detail record of all my initial measurements, so if a problem occurs during final parts replacement, I should be able to track it down quickly.
    Silver1omoPWRRYDkenrhodesjhollandersquamishdroc6thplanetkennykrjj45
  • That's in beautiful shape! It looks like it had a pretty pampered life. Much cleaner inside than my old Hickok. I'll have to keep my eye out for one of those. Have you come across any tubes in your collection that aren't listed on the roll?
    It is an IG-18 and I am familiar with the mod. Not having a distortion meter I never bothered with the mod and I was never worried about the meter accuracy.
    Yes, I've only had this tester for a couple years, but when working on an old 1930's radio, I noticed that the old 4 pin style radio tubes (27, 47, 80, etc) were not on the roll chart. I think Heathkit removed older tube types from the roll chart to make room for newer ones. A note at the end of my roll chart shows a date of 1969 and I have Heathkit supplemental update sheets that include old as well as new types out to 1978.
    One of the downsides of this tester is the meter. From what I have read, it can be a real problem because there are a few small parts (precision resistors, diodes, and inductors) inside the meter case that can go bad or drift out of tolerance. If they do, you will never be able to calibrate the tester. And fixing the meter is extremely difficult because you have to completely disassemble the tester to dig the meter out. Then you have to be very careful not to damage the meter movement when you tear it apart. Luckily, my meter seems to be OK.
  • Time for another Heathkit. Here is my model IG-72 audio generator, which I built from a kit in 1974. It uses 3 tubes and produces sine-waves only (1Hz-100kHz). I used it for years to measure woofer T/S parameters before getting a Dayton WT3. Nice little unit; I still use it for woofer break-in's. I also have a BK function generator for radio work, but it looks very bland compared to the Heathkit.
  • This isn't a piece of test equipment, but I built an extension for the back of my desk and included this little cubby to hold plano 3700 boxes.
    I thought that a modified version of this idea may work for for someone else's storage needs.
    dcibeljr@macSilver1omokenrhodes6thplanetTurn24thtrysquamishdrockennyk
  • Roughly 20 years ago, I built Joe D'Appolito's Mitey Mike. I mounted a Panasonic WM-60AY mic cartridge on the end of a long brass tube and bolted the tube to the end of a small aluminum box. I then mounted the mic preamp circuit on a small perf board and powered it with a 9 volt battery.
    I had it hooked up to an M-Audio soundcard, feeding Speakerworkshop on an old Windows XP machine. It did not work very well at all. I spend most of my time fighting with the software, adjusting and re-adjusting the volume. Most of the time my measurements came back completely garbled. I finally gave up and bought an OmniMic. I still have the mic, but it no longer works because I borrowed the battery holder for another project.
    kenrhodesjr@mackennyk
  • This is my newest toy, a Levear (Panasonic) am/fm stereo signal generator. I have been wanting one of these, and I took a chance on an Ebay find.
  • Nice! Aligning tuners has become a lost art these days. Are you getting set up for a retirement gig?
  • So I got scammed on eBay 2 weeks ago when I bought an E-Mu 0404 audio interface. Ebay is no help, so I'm out $80 on that deal.
    But sometimes karma has a way of throwing you a bone - I found a used Digilent Analog Discovery for much less than what others were asking. It arrived today and it's clean and working fine! This weekend I'll be running the same Audio Analyzer Suite that I've seen on quite a few hifi restoration videos.
  • Let us know how that works out, I don't really care about the oscilloscope function, but the spectrum analyzer looks interesting.
  • I looked at one of those and even signed up for academic pricing on it. But the Analog to Digital converter on it is only 14 bits. So it is helpful for many things but not sensitive enough for definitive evaluations of electronics. It is probably sufficient for speakers.
  • Found this at my local habitat re-store. An almost mint condition Heathkit PS-4 high voltage power supply. Have not purchased it yet, as I wanted to do a little on-line research first. Turns out, this is exactly what I am looking for. Should be a fairly easy re-cap. Looks very similar to Tom's Oregon A3A power supply that he posted above, just a little bit smaller. It uses a pair of 6L6 tubes and can output a regulated 0-400vdc at up to 100ma, a separate negative 0-130vdc for bias, and 6.3vac @ 4 amps for filaments. Seems a little pricy, but this is actually about half what these things go for on ebay. Hopefully someone will not grab it before I go back to pick it up.
    ugly_woofertajanesjr@macjhollanderrjj45
  • edited June 2024
    Very cool. I wouldn’t have a clue what to do with it - but what’s not to like.
    Same reason I’d like to get a nice reel-to-reel with VU meters - turntables are kinda cool - but don’t do it for me like the reel-to-reels. An old high school friend had a reel-to-reel (A/V and band member) and another friend’s dad was all about McIntosh.
  • Bill, find the manager and make an offer. My restore often has 50% off sales. Chances are if they are looking at a $50 offer they'll take it. It is a very nice peice of kit.
    Good tip. I'll give that a shot and see what happens. This particular re-store has a four color revolving price tag system to help clear out unsold inventory. Price tags are white, blue, tan, and green. On the 1st of every month, they rotate the discount percentage given to each color price tag. Items not sold after 1 month are 20% off. Items not sold after 2 months are 50% off. And items not sold after 3 months are 75% off. I could wait for 2 months and if it was still sitting there, they would ring it up at 50% off, but that might be too late. I am sure someone else would buy it before then.
    I am a sucker for reel-to-reel as well. When I was much younger, I had a Crown SX-724 reel-to-reel machine. I can still remember recording and playing back master tapes at 15ips, watching the big 10.5" reels spin and the giant VU meters bounce. Way cool!
    tajanes
  • $50 for that PS would be a steal of a deal! If someone else grabs it, I have a huge boat-anchor Lambda PS that I'll just give you in October. The downside - it takes multiple 6L6 and other tubes and it's heavy!
  • What was sitting next to it? Looks like something from Tektronix.
    That is an HP 206A Low Distortion Audio Signal Generator (circa 1959). I looked up the service manual spec's: 20-20kHz in 3 ranges, 1% accuracy, less than 0.25% distortion, 14 tubes including two 6L6GB's, weight 57 lbs!! This is one, big sine wave generating machine!! How would you like to have this monster on your test bench?
    6thplanetScottS
  • That's a beast! I'm surprised it takes 6L6s to output 4.5v into high impedances.
  • Pulled the trigger on the Heathkit. Wanted to get it home before someone accidently "bashed" one of the meters. This is a high traffic store, with lots of big furniture moving in and out of this area on a daily basis. I've seen several nice antiques get badly damaged just sitting on the sales floor for too long.
    Front panel is almost mint, with one small scratch on the top, left corner. Should be an easy fix with a small dab of gray touch up paint.
    Looks like it has a complete set of the original GE/Heathkit type tubes. The 6L6 tubes are stamped "Made in the USA for HEATHKIT by General Electric Co" They both test very good, indicating that this might be a very low hour set.
    The underside is very clean and looks completely untouched since the original kit builder probably put it together back in the mid 60's. I can tell that this was not a factory wired unit, as some of the soldering is a little blobby looking and some of the wiring is a little "wonky" in a few spots. But not too bad at all. I can work with this.
    a4eaudiojr@macjhollanderRon_ESilver1omokenrhodesugly_woofertajanesTom_SNicholas_23and 4 others.
  • So did you barter? Even at $100, it's worth it for the tubes!
  • And those power xformers
