Project Code Name BILC
  • @blue934 said:
    Gorgeous package!
    Any chance you still have the files for the trim rings?
    I’ll ask Dan. He did the CAD.
  • @Kornbread said:
    @NavyGuy said:
    Just a snug fit. I might regret that later if the plywood decides to expand too much but I guess we'll see.
    If they come loose how about gluing some small neo magnets in the four holes on the underside of the trim ring? I suspect they could be aligned close enough to the woofer frame edges or mounting screws to hold the trim in place.
    ... and super nice build.
    Thanks. I couldn’t find any neo magnets quite small enough to fit the holes.
  • Check Menards, they had a bunch last time I checked.
  • Look for some "bucky balls" i think that are 3mm round. Work great for stuff like this.
    Hey, thanks for the heads up. 3mm would be perfect. It's been a while since I looked, but I was looking for discs and couldn't find anything under 6x2 mm if I remember correctly and I really needed something closer to 4 to make sure I didn't have issues.
