Hi guys.
I've just got started on my latest project which I hope to demo this fall in Iowa.  It is a monkey coffin 2-way using Eminence Delta Pro12A woofers and the newly released Tymphany DFM-2536R00-08 compression drivers in SEOS12 waveguides.  I am using a MiniDSP 2x4 and two TDA7492 amp boards powered with 19.5 V laptop SMPS bricks.  Modeling shows the drivers will output over 102 dB with only 15 watts (after BSL) so those tiny amp boards should be more than enough.  I am excited to start playing with the MiniDSP.  I should have the rough enclosures ready for driver measurements by next weekend.  Here is a picture of what I've got done so far:
