Don't do this.
I'm building a 3 way around the 8" MCM woofers. It's kind of a complicated cabinet that I will document when the system is done. In the meantime, the front baffle is comprised of a picture frame made from a sandwich of 3/4" solid walnut, mahogany veneer, 1/4" maple, and another layer of mahogany veneer. Glued to that is the front baffle of 3/4" walnut. Yesterday I glued and clamped the baffle with all the driver cut outs to the picture frame layer which had already been glued to the box. Shortly after I got done I realized it was on upside down. I quickly unclamped everything and popped it loose with a hammer and turned it around. I'll try not to do that again. Today I cut some nearly 1 1/2" 45 degree bevels around the front baffle. That's when I discovered something you shouldn't do. Don't put biscuit joints near the edge of a front panel you want to bevel.
It's a pity that I exposed the biscuits because the end grain on the bevels and the birch mahogany sandwich would have been perfect. Looks like I'll be learning to do some inlay work.
  • Looks good to me, the exposed biscuit actually adds an interesting focal point...
  • I think it would looknsweet with a pearloid inlay. I have inlaiednleaves and decorative scrolls in the past. Really is simple of you take it one step at a time.
    I'd go for it if they were all the same but they're not.
  • Rare set of mistakes by a fine craftsman. Thanks for sharing!
    In my woodshop, I am usually thinking "How can this be screwed up, and can I recover?"
    On one project, I had to cut a new baffle 4 times... lol
  • The inlays were a bit of work but they came out just fine. I cut the inlays and made a jig from 1/2" plywood so I could use a small top bearing bit to cut the inset for the inlay. I used a chisel and various Exacto knife blades to remove the wood left in the corners.
    Last night I tried to put the drivers in one of the boxes and discovered the woofer wouldn't fit. They dropped right in before I put a coat of Watco Danish oil on the front baffles. It must have made the wood swell so now I have to try to recut the rebates without messing things up. It's always something.
  • I would verify that it is dry before recutting. If this is a tempirary swell it may go away and stay gone.
    I just got back from recutting the rebate. My original template was a little oversize so I'd put a couple of layers of tape on the bearing of the router bit and the hole was a nice slip fit. The top and bottom of the hole were slightly undersize but the width was much worse. The woofer has a little play in the hole now but that's probably OK with a solid wood baffle.
  • This, in my opinion, is one of the most frustrating parts of speaker building.
  • Everything fits. :-)
    Now it's on to getting the finish whipped into shape and then it will be crossover time.
    4thtrysquamishdrocScottSdcibelGowajholtzSilver1omojhollander6thplanetR-Carpenterand 3 others.
  • Nice compact 3-way, Ron!
  • edited November 2020
    Oh for my successes to look like your mistakes... Beautiful work!
  • I'd give these a solid 10 for craftsmanship. The inlays give the baffle a very distinctive look that blends well with the drivers and frame. Good thing you accidentally exposed those biscuits. ;)
  • Great looking speakers! I hope to see them in person some day.
  • Should the title of this thread be "Do this, if you can".
  • Thanks everyone. When they're done they'll be going to a friend in California. I have another pair of the MCM woofers so I may build another pair in time.
  • That was an excellent idea, I would not have thought of that solution, and I would have just made a new baffle. Nice save.
  • nice looking speakers
    I'm curious, what are the dimensions, and your targets for Xovers? thx
  • The external dimensions are 10 1/2" D x 12" W x 22 1/2" T with an internal volume of 1 cu. ft. I'll probably cross at 1K and 5K depending on measurements.
  • Beautiful cabinets Ron! Your cabinetry skills always leave me in awe.
    I predict this will be an exceptional speaker design that sounds as good as it looks.
    Jim
  • Your work is always so super clean and tasty, it's a real aspirational goal for me.
