New Seas 27TAC/GB, some facts, some opinions, and some data...
edited August 2019 in Hard Data
I recently purchased a pair of these from Meniscus. They are not on their website yet. I e-mailed my inquiry. Mark hooked me up.
Seas website blurbs:
http://www.seas.no/index.php?option=com_content&view=article&id=561:prestige-titan-launch-news&catid=41:news&Itemid=194
http://www.seas.no/index.php?option=com_content&view=article&id=556:h1825-06-27tac_gb&catid=45:seas-prestige-tweeters&Itemid=462
Here is the retail price and info on MAD, just for more information:
https://www.madisoundspeakerstore.com/hard-dome-tweeter/seas-prestige-27tac/gb-h1825-aluminum/magnesium-dome-tweeter/
It supposedly is simply an improved 27TBFC. Copper cap where there was not one before, titanium (Titan line) voice coil former, a reshaped and carefully damped chamber, as well as being shipped/sold in matched pairs. I'll admit, the $91 price tag seems a bit high for production with a glass-reinforced plastic faceplate, but truth is you don't find titanium formers in very many drivers that cost less than $100. Normally they are aluminum, glass fiber, or Kapton. Seas uses a Corian material in their diamond line tweeters, so maybe they don't use metal faces often either. (I see Excel units are cast faces) The faceplate is really thick when it comes down to having plastic faces of any sort, along with what appears to be a metal hexagrid. The chamber cup and integrated divot remind me of those in the DX/XT line from Peerless, basically a sinusoidal curve of Pi length rotated around the Y axis. It's not quite a half-torus shape. Being that the TBFC is a bit splashy, and these have a copper cap to reduce HD, that is what tickled my fancy. More on the tweeter choice will come when I start posting info about the design path.
My first run-ins on the trusty ol' S&L WT2 left me perplexed, as this is the spec sheet info:
I see the spec sheet as 900 Hz and 13 ohms, not 830 Hz as listed. And these are what I got:
The second one has a higher magnitude, but otherwise looks to be normal. Obviously, I would not call these a matched pair were it my judging. Mark said he noticed that as well, as he had measured them before he shipped them out and wondered if I would also raise an eyebrow. So- he shipped me another pair, with one that matched #2 above rather well, and another that appeared to be a bit 'off the mark'. I'm a bit disappointed in Seas for having these sold as a matched pair, and that there was this much discrepancy in a $180 pair of tweeters. I would think that this much shift would be unheard of at this price point.
He also said they will be QCing drivers for better matching tweeters, etc, and including the DATS T/S runs on a nice sticker that you can slap on the driver magnet. The sample stickers I got look pretty cool. I don't know if this will be an offered service, or if this is something that they will be doing per order as they come for free. You'll have to contact Mark about that. Either way, I as pleased I was able to get a matched pair through their diligence. He let me keep and tear into the other pair that weren't as accurate as I saw fit.
Here are the measured data of the second set:
Number 2 and 3 overlay with only about a half-ohm magnitude difference at resonance, and the T/S are really similar as well. I imagine these will be really close over all.
Being the recent practice I and others have had at adjusting the tweeters' specs, I used Bill's method of a putty knife prying up around the surface to loosen and remove the cap. This worked really well for these 2 tweeters, and I didn't have to saw a gap first as the knife fit between without adjustment.
First subject, #1, had about a 1" cotton ball wedged between the inner side of the divot and the vented pole piece in the magnet. That was all it had behind the magnet. There is also a felt ring atop the pole, which is generally a good addition in terms of FR. As in my normal tweeter adjustment MO, I gently inserted this into the pole-hole, and added about a 1.5" square of Ultratouch 1" thick. Then I glued the cap back on with E6000 and awaited cure for remeasurement. This was the result:
The Q parameters were a bit higher, as was the Fs, but this is a lot closer to spec than it was. I would even call this within tolerance compared to the 'approved' pair.
Tweeter #4 appeared like it would be additionally perplexing. The tangential sway above resonance from the typical roller-coaster impedance was a head-scratcher. I did the same mod to this unit as I did to #1, and resulted in this:
This had a shape that was more like the others. That 'sway from 1k to 1.8k was still there, albeit at a different magnitude. Well, I didn't think that tearing back into the rear and stuffing would change anything for the better, as it should look like the other 3 if that were the inherent cause. OK, time to remove the faceplate and see what I can observe...
The surround is glued to the rear of the faceplate, so be careful if you remove the faceplate. Another note about the faceplate is that the polarity markers are really hard to find, and are on the structural cross-members. They are not on the terminals or the terminal supports, so I marked mine with a red Sharpie. They were also hard to see in the photo below, so they are enhanced for detail.
More in the next post...
  • On the frontplate, there are divots/notches in 2 places between the mounting holes that seemed to correspond to the notches in the faceplate structuring. Nice copper cap is shining there!
    I have no idea if they are supposed to align in a certain way or not, but I figured a 90* rotation was not out of the question due to how the interface was designed. I recall a time where Peerless/DST had issues with their DX25/XT25 tweeters' faces warping during the manufacturing process. In some cases, a simple one-position-shift of the mounting screws would solve the measured out of spec differences in those tweeters. That company decided to just start gluing the faces on to solve the issue. I have not heard of this problem with them since. I figured it couldn't be that simple, but why not? This is the result:
    It's a little higher in magnitude than the others, but the T/S align really well with the other one I modded.
    Just for comparison sake, here is the final results of the modded on the right adjacent to the factory ones on the left. I included a blurb of the previous abnormalities just for fun:
    One more thing- #4 had about 3x as much cotton in it compared to #1. I wonder if Seas is not metering the stuffing amount as they hand-assemble these units. I am pretty disappointed that they were this vastly different initially- especially at that price point!
    I am going to compare FR/HD and listening comparisons when the time comes...
    jhollanderani_101S7910kennykrjj45JasonPGowa
  • Are these, the rst28, and the like coming out of the same Chinese factory?
  • Uh, nope. Seas are hand-made in Norway.
  • Doesn't Seas have a Chinese connection?
  • I don't believe they do.
  • Owned by Chinese, okay yes. I actually forgot about that. AFAIK, though, they still assemble and manufacture all of the drivers in Norway.
  • edited August 2019
    The only indication I can find about locale of manufacture, and it does not exclude parts made elsewhere, "Many critical parts are produced in-house; some of them by special purpose machinery designed and built by ourselves", and that comes from their website;
    So ... not saying some of their stuff IS manufactured elsewhere, like China, but I see no mention that all of their stuff is made in-house.  That little snippet from their website leads me to believe they do, in fact, outsource at least some parts.
    Is it more than coincidence that the rst28 has a similar issue?  You discovered that mistake (PE owes you some serious coinage for doing their QC/R&D work), and we know it is made in China.
    Do other Seas tweeters use the plastic faceplate?
    The question begs asking: You have a 50% failure ratio from a reputable manufacturer, what has happened?
    kennyk
  • I have a pair of 27TBFC/G H1212 and they have plastic faceplates.
  • The Excel line states cast metal faceplates. The rest for the most part, I don't believe they are metal. This tweeter does however have a NEW plastic faceplate that is a bit sculpted and not flat, and has the bead-blasted texture on the surface.
  • Yes, those plastic faceplates sound quite a bit different (better) than the ones on my tweeters.
    I'm pretty sure Pot is legal in Norway. Just sayin'
  • Saying what? Sweden it's legal, dunno bout Norway. At least here, even if legal, companies can still pink slip those under the influence. It's just like going to work drunk. I don't know if they feel the same over there as we do here. I would hope that SEAS would not be happy with stoned out employees assembling their drivers.
  • Thanks for the data Ben. It is interesting that I feel in some ways SEAS just keeps putting out new driver with no actual innovation to just try and attempt to stay relevant in the modern world (as their solid designs age). I got a kick out of this from the titan launch page:
    "Low mechanical and electromagnetic damping ensure high quality reproduction of even the finest micro details in music. At the same time the high-performance titanium voice coil former and its connection to the cone has very high powerhandling, suitable for modern amplifiers (e.g. Class-D). Therefore, the driver has exceptional high dynamic capability, which the light and stiff aluminium cone or dome transfers into clean and undistorted sound, suitable for modern High-Res audio."
    Sensitivity dropped (from the 27TBFCG), moving mass increased (slightly), and resonance moved up massively. Better get my class D amps ready for this monster.
    kennyk
  • The loss in sensitivity is also related to the copper cap. It reduces the magnetic flux. The Mms is likely due to the anodizing. The chamber is smaller than the TBFC has, and Fs is only specced at 830. It really is not a TBFC any longer, as a lot of changes occurred. Also note the lack of an F in the model, as there is no ferro-fluid.
  • Some notes on what I'll be doing with these... currently dubbed 'EMP'. It's a play off of PMC, with more musically related titling.
    Basically, a small format TMM consisting of Seas Al/Mg 27TAC/GB and a pair of Peerless 830991 glass-fiber midbasses in a ~30" tall tower. It's meant to have really low HD for minimal cost, and be a designed update/improvement to the PMC 'Twenty5' design- or at least initially that was the goal. The '25' appears to use the 830991 singly with the 27TDFC as the tweeter, formerly the 25TAF. We'll see where it comes out in results.
    The Titan 27TAC/GB I'm using is a serious upgrade over the previous tweeters, and Joachim Gerhard measured it to have the lowest HD of any similar tweeter with level being at -65dB from 2kHz up. I found this out as an added bonus after I made my previously noted purchase.
    The tentative F3 is ~45Hz, and a target sensitivity is ~86dB. The midbasses are of the series that RobSan tone-burst tested (830992) to have the lowest HD for the cost, and rivaling that of much more expensive drive units. Using 2 of the drivers will up my sensitivity, further reduce HD at output by halving Xmax requirements, and allow more room pressurization before rolloff. The '25' sounded really good and had extension, but seemed the level at that extension was a bit reduced in output. Using 2 will improve this.
    Design being a short tower means optimizing for above the tweeter axis, 10" at the listening position. I designed for this to have an increasing lobe direction instead of being straight forward. I did this with the Nephila, and it did quite well. The summation in the EMP still aligns well even below axis, so I feel this is a good compromise. The comb-filtering of the woofers in addition to being mainly (above) off-axis contributes to a large hump at about 200Hz I had to filter out. This lends to a more complicated xover in the bass range, but leaves the unpeaky rolloff of the glass fiber cones rather straight forward. I'll be playing with the woofer rolloff, but it appears that 3rd order works better above the tweeter, and the 2nd order works better on the tweeter axis. 3rd on the tweeter electrically was my result, plus a couple other things. Since the tweeter has no FF, I comped the Fs with a full LCR. The 27TAC FR exhibits an ultrasonic breakup at 25-27kHz, which I also have a notch to compensate. I will have a switch on this and will be measuring both with and without the notch engaged to both see and hear the performance differences in measurements and listening.
    Initial simulation:
    The reason for the bypass caps is for use on this ultra-low HD tweeter, to see if they are audible. I'll have a switch on this too.
    I have the initial xovers mocked up, as well as the 4-sided cabs constructed at this time.
    Looks will approximate this:
    More to come as it goes...
    JasonPGowasquamishdroc4thtry
  • Excellent woofer choice, I like both the 830991 and 830990 woofers. I was surprised at how well the 991 kept up with the excellent SB26ADC tweeter in a build. This should be a great combo, IMO.
  • Interesting woofer mounting  B)
  • It likely will not be cardinal mounted. It's only a render.
  • Couldn't stop myself, and bought 4x 0.1uF 500VDC Silver-Mica caps as an alternative bypass cap. You're wondering where I got them, aren't you?
    Sovcom: https://www.ebay.com/itm/4-pcs-0-1uF-0-1uF-1uF-500V-2-Silver-Mica-Capacitors-KSG-2-Russian-New-NOS/202556775527?hash=item2f29531c67:g:zHUAAOSwq~tZW2~U
    You can't get Silver-Mica caps this large on this side of the pond, and the Russian stuff seems to have a good reputation. The price was right! They are more gold-tan than the yellow pictured.
    So- I have 0.1uF PIO Russian K40Y9 and 0.1uF Ag-M Russian KSG caps. The PIO is supposed to warm up lower treble, and the Ag-M is supposed to be the best caps in the upper range- repp'ed as better than polystyrene.
    We'll just have to wait and see....
  • Is it $13 for 4 of them?
  • Yes- plus shipping.
  • Since I have 4 of these tweeters, a second project has developed with the Seas U18. Hard to believe it's now a 10 year old driver design, but I've loved the U18 and U16 everytime I've heard them. The model is done, and I'm quite impressed!
    It came out LR2 through the xover.
    The higher Q tweeter rolloff coupled with the BDC signature needed a 3rd order of pretty low Q to achieve even a 2nd order rolloff.
    The woofer has a dip in response at about 800-900, and this flattened out with the BDC signature, leaving a very minor magnitude dip. This coupled with the woofer's ability to work with a single coil makes this look really good to me! I used zaph's 10 year old FR measurement.
    See for yourself:
    If it wasn't for needing the Fs spike tamed, this would be a small parts count.
    BrannigansLaw
  • Well, some more information has arisen, as I now have measurements of the 27TAC/GB in situ, and of 4 samples seen earlier. Frankly, my modded units stomped the stock ones! :o These measurements are for the EMP as she sits currently, and I'm quite happy with the performance. This is with the Ultrasonic cut disengaged, and no bypass cap in the circuit.
    Stock unit:
    Modded unit 1:
    Basically the pairs that were matched reflected each other really well, so I won't post duplicates. These measurements are all with the right channel woofers.
    I was really surprised that the sssibilance, minimal at that mind you, was actually a result of the HD signature and not having enough or ill-placed damping in the chamber.
    JasonP
  • Did not know you used omni mic and now XSim... Nice x-o and labels. Part count reminds me of a horn 2-way
  • I use Xsim when I can't do it in PCD. I used it on the Cecropias too for the funky Lpad it required. I had the file already made in Xsim from the initial model for comparison, so I adapted it and threw it up on here. I've been using Omnimic since about 2016, but I've had it longer than that. I don't always pull it out and measure to verify. There was a full set of graphs made for the Zingers.
  • These apples look better...
    Final schematic:
    Changes made yesterday-
    • I elongated the port another 1.5", which placed the tuning at 42 Hz. A couple pocket-hole screws seemed to be the best way to lengthen a slot-port. There was just too much bass and sounded a bit imbalanced. Target was 46Hz, and I was at 50 Hz before. I still have a bit of a peak at 78 Hz that I'm hoping a bit more stuffing will ameliorate. Mind you, the bass never sounded boomy, warm, or even pummely. It just had too strong of a magnitude.
    • I had the resistor in the bass EQ bypassed to see if that helped the mids, and it did help, but not enough, and it created a weird tuning and impedance profile, so this returned to the 1.5 ohm value. The measurements before these above were bypassed.
    • I added the 24uF cap. I used a Clarity SA becuause I had them, and that brought the midrange up where it needed to be, bypassing the added resistance in the Bass EQ from both resistor and capacitor. This brought the mids level with the tweeter.
    One of many things that are different about this build for me, is that there is no major bracing in the middle of the panels. All of the corners in the box accept for the side-to-top junctions have added corner bracing. This is due to the slot-port, the inner rails to mount the baffles, and the pieced rails to either side of the xover docks in the rear panel to make the width I needed. The sides/top have 4" square 1/4" thick marble(?) tiles with the mass-loaded Sonic Barrier chunked between them. The inside top wall of the slot has a thick rubber slab and 1" SB foam. Then I laid 2 layers of 100% wool batting over the back-mounted xovers. I will be adding more of this to hopefully tame the 78 Hz peak.
    But I digress... AND- I used plywood.
    The box is very strong and does not resonate. I managed to get rid of the plywood box hollowness that I despise using the techniques above. I don't normally use ply much, but it is easier stapled to than MDF. This meant that I could do the finish I want. More on that part later, but I'll have some of Lowell's spiked feet outriggers on the bottom.
    Pics of assembly to come shortly...
    Ben
  • Docking rear panel:
    Tiles on side panels:
    Sonic Barrier with mass layer applied:
    Peerless trunky-circle jig:
    Removable baffle mount and brace:
    Inner end of bottom slot before elongation:
    6thplanetJasonP4thtry
  • Tweeter recess:
    When I cut the tweeter hole, I wanted to measure Fb, so I made up a Tuner-Tester like they describe in the LDC, and Joe's 'Testing Loudspeakers', technical drawing of mine:
    This allows me to test the Fb by placing the stuff in the cab that should be there, and not yet cutting the woofer holes. It will be a valuable tool to use on cabs in the future. No reason to show my poor-looking implementation.
    Rubber tile and SB on the inner bottom:
    Added 1.5" to port length:
    Stuffing:
    Terminals/switches:
    Rear port exit:
    4thtryrjj45
