So, no more TB W3 1797S. I need a replacement. Say around 70-100 per driver. I am also going to change the design a bit and want these mids to cross over very low to a pair of side firing woofer/subs. efficiency need not be too high, a the subs are around 84-85 db and will be in series for an 8 ohm load. Will want to cross over to a tweeter as high as possible, so the mid is carrying the bulk of the audio spectrum. I do have a bunch of tweeters, but some additional tweeter choices will also be appreciated.
the sub woofer are TB W5 1138SMF. In the meantime I am going to dig through my driver stash and see what I can come up with.
How high do you want it to go?
+1...
The 10F is a fantastic midrange.
If there are any other suggestions, please let me know. I am going to wait till I send back the other drivers, get my refund (maybe minus some restocking fee, etc) and then take a call.
There is also an Eton (Eton 5-200/A8 Symphony, 5" Mid/Bass) for 89$. Is this any good at this rate? The specs and the published ditortion look good, but that is only half the story...
The 10f is wonderful.
Many forget about this guy I used in the "Dark Knights" and was well loved. i think it has slighly better low midrange response than the 10F, but the 10f edges it in inner resoultion.
https://www.madisoundspeakerstore.com/approx-4-woofers/seas-prestige-ca12rcy-h1152-4.5-coated-paper-cone-woofer/
There is a dedicated midrange version if you search, but not to be run lower than 300. (they say 400, but its beefy).
