Rival 8-3/4''
  • Yes, I'll be picking them up Tuesday.
  • Ya got specs on the 8¾? Probably use it in the next project.
    No, the supplier and I are not seeing eye to eye at the moment. Now I'm not sure if I will be getting any. :(
  • If you think the deal is a wash then I'll probably relieve Joey of some goods.
  • edited August 2020
    I've been away. I took some time with some buds to go north to the woods. I needed that. Heading back up this week.
    7'' Rival OEM
  • I thought you got your hands on the 8¾ ...
  • Nope, just 7s
  • Is this still a go for the 7'' Rivals?
    2 - Ron_E
    2 - Kornbread
  • I'm in for the 8¾.
  • No 8-3/4''. I won't be getting any more drivers after these 7'' for various reasons.
    7'' = $66.25 each
  • What is the nominal impedance, Fs and Qts for these 7 inch drivers? And are these measurements made on broken in drivers or right out of the box?
    Shawn
    Boo.... Some day a set of CF for cheap will be mine.
  • Nom: 8 Ohms
    FS: 34 Hz
    Qts: .3
    SPL: 87dB/1w/m
    Shawn
    Not broke in.
    R(e) = 7.29 Ohms
    f(s) = 33.30 Hz
    Q(ms) = 7.166
    V(as) = 31.54 liters
    M(ms) = 21.09 grams
    Q(es) = 0.308
    C(ms) = 1.15 mm/N
    Sd= 131.000 cm²
    Q(ts) = 0.3
    L(e) = 0.177 mH at 10kHz
    BL = 10.06
    SPL = 87.5 dB SPL 1W/1m
  • @Ron_E said:
    I probably shouldn't, but I'll take 2.
    The woofers arrived in good shape. Nice looking driver.
    Gowa
