Hey All,
I'm working on a monkey coffin with the following drivers: Transducer Lab Ceramic tweeters, Satori MR16PNW midrange, and DIYSG Magnum 12 woofers.  The goal is 90-91db efficiency with an F3 between 40 and 45.  I will be doing roundovers on the edges and a separate housing for the mid and tweeter sections.  Cabinets will be mirrored.  I even considered doing different designs on each one--sort of a Soviet versus US space propaganda.
(1) Before I start drawing up blueprints, I would like feedback on the very rough mock up below.  The design idea is a tribute to the stereo era, as well as to the golden age of space exploration.  Admittedly, there are preferable [acoustic] ways to design a cabinet today, but I'm trying to do the best within the confines of this general aesthetic.
(2) How recommended is a waveguide on that tweeter on such a wide baffle?  It should naturally cross around 2k to the Satori, but I'm wondering about diffraction on such a large baffle, or anything else tweeter-wise I should be considering.
(3) Any other thoughts or foreseen design challenges before I get into it are most welcome!
Thank you!
Answers
I never understood imaging vs baffle width? Would s tapering tower have better imaging?
Dual ports at the bottom would avoid the diffraction be issue, but still look retro.
2. Take polars in both directions.
3. Compare.
Baffle width is not really correlated with imaging, at least not to my knowledge.
1) Regarding felt, are we talking like Ryan Audio (which also happens to have an offset) or Spica TC-50 [see below]? I'll need to look for the thread--I'm definitely not opposed to the idea. In this case, does the felt diminish the need for cabinet roundovers since you are dampening the high frequencies, or is it still recommended?
2) Noted on the port placement, so either below the woofer on the front, or move them to the rear panel. Makes sense, and thank you!
3) Troels has done a mixture of classic 3 ways. Most have horizontal offset mids and tweets. Are these naturally inferior to a centered design (e.g. Harbeth 40.2)?
4) Lastly, in the interest of making the most out of the drivers, I suppose the design could also go a different direction, with a slight trapezoid shape. Oswald Mills Audio makes some esoteric looking things for the audiophile community. Their monitor is a hardwood frame with dovetails and a slate baffle. I'm not using slate, and I am concerned that hardwood would run the risk of cracking, just referencing the shape.
Sorry to flood the thread with photos, just showing examples of what I'm talking about.
Ryan Audio R630
Spica TC-50
Harbeth 40.2
OMA Monitor
All, thank you so much for the input! I took much of it and came up with this. A departure from the earlier design, but I still like it, and the non-parallel sides have their merits. My son said I needed to make something with dragonflies (his favorite insect), so here we are. Though not reflected in the picture, the baffle will be flush with the walnut, and the top will slope towards the rear panel--to avoid the temptation for people to place something on top of them. Please feel free to pick it apart or make suggestions. I really appreciate it!
Note: this is no longer a true monkey coffin--so it's now a misleading thread title. Sorry!
Nerd bug trivia: The dragonfly has an estimated 95% success rate in capturing prey, making it the deadliest hunter on earth. They are also the fastest insects.
That said, whether or not people appreciate it, the slope says "this is not a plant or drink stand."
