So if you guys were going to buy some front end electronics (AVR/PRE-PRO, AMPLIFIERS, DSP/EQ) and keep things under $3k (new, refurbished, used) what would you go with?  I currently use a Denon X4000 and a handful of QSC CX pro amplifiers.  One thing I hate is not having any clue or adjustability on the substage.  XT32 (circa 2014) does OK but not great on everything else.  The QSC amps are reliable, great power, but produce incredible amounts of heat.  I run my subs as "two" subwoofers, the four 13A's as "one" subwoofer and the two 19O's as the "other" subwoofer.
I'm fairly green to all the products that are out there, so figured you guys may be able to shoot some ideas.  Trinnov looks ridiculously expensive, Dirac is limited and Audyssey gets mixed reviews.  I'm hoping to go with efficient surround channels so An AVR isn't out of the question but I don't mind amplifying either.  And the substage will be efficient all around once the 19O's get rebuilt.
Thanks and should be fun seeing what comes up!
I've heard about a number of problems with Emotiva prepros, so I can't reco those, but the setup of separate prepros and separate amplifiers will give you a lot of flexibility. I haven't heard one person ever criticize Emotiva amps, and would be looking at a great separate amp for the front LR, and let the HTR handle the surrounds and sub feed.
Besides the standard "24 or 32/192" DACs in HTRs, poking around the high resolution audio forums shows DSD256 and some others. I just looked up a Marantz SR6014 and it shows: decodes DSD 2.8MHz and 5.6MHz tracks
Basically, your setup shows me "I am not worthy!"
The Denon has been great but as stated before. I've had Emotiva products, the UMC wasn't bad at all and I never should have sold my XPA-3.
I've stumbled on the Antimode for the subwoofers and may give that a shot, there's always the miniDSP.....
Someone buy my stuff.🤣🤣🤣🤣
