Impedance variations in tweeters
I ran into this while testing drivers with LIMP:
Published fs is 1475. So the yellow line is right on. The second tweeter (green) has a higher fs. I also tested a pair of Dayton ND16 tweeters. And they had a similar graph/issue. Just at about 1k higher. What does this mean? Anything?
  • No worries.
    duanebroMzisserson
  • The kb drivers are right on btw!
  • I second JR. Also what I look for in tweeters is a second hump, or plateu just past fs as the Z is normalizing which usually means a leak somewhere.
    Also, any squiggles after the FS which can show motor issues
    duanebro
