Amp board for 150W into 8 ohms - which one?
Look for an amp board which can supply at least 150W into an 8 ohm load, ideally 200W into an 8 ohm load for a bit of head room and reasonable THD. With a lot of the boards being rated at 3ohm for dismal power and THD, is this a very high requirement? also ideally a stereo board...
