I was modelling a couple of driver and like the response and box size, but ran into an issue with port chuffing. At full tilt, port chuffing is pushing 80 m/s. I am planning to have the port on the bottom of the cabinet, but assume this will still be audible. Would a heavy carpet or a pad of stuffing under the speaker help muffle some of the noise? Any other suggestion? Increasing the port size i tun into too long of a port...
This is with 100W per driver for a max response of 106db SPL
The 2" port required around 8inches in length, much more manageable. Usually I model around xmax, but expecting a 5 incher to hit 31hz at 106 db 1m.... It does have 9" for xmax
Would love to overbuild, but the design choice asks for a compromise, would like to know how bad of a compromise it is.
Also consider checking the port resonance box if that is unibox so you can see where the port resonance shows up.
Hi Ani,
Sorry for the late comment, just found this thread. There was a Speaker Builder article published many, many years ago where a fairly experienced builder did port compression analysis using a 10" woofer and, as I recall, several port diameter sizes ranging from 2 to 6 inches. He published several graphs showing comparative SPL compression effects at low frequencies. I'll dig through my SB back issues, find the issue, and bring it along to Indy.
Bill
If I find the PDF on my disk, I'll post a Google Drive link to it.
Ani, Found the article that I was looking for. It was published in Audioxpress mag Sept 2001. It was written by Bohdan R., author of the Soundeasy software package. Here is a link to the article:
https://audioxpress.com/article/how-good-is-your-port
Bill
