Bohlender Graebener Neo10 Planar Transducer is up.
Klif's notes: Very non-linear frequency response. Odd things in the unit-to-unit consistency with regards to the distortion. I know people have used them and liked them... I don't see it.  Maybe there's a legit use for them that I'm just not aware of like line arrays (as the marketing indicates). Either way, I can't recommend them for 'standard' speaker applications based on what I'm seeing here.
https://www.erinsaudiocorner.com/driveunits/bg_neo10/
Measurements are not everything.
Measurements are insightful. And that insight helps determine applicability.
I looked up Dan's Echelon's. Found his discussion about them here:
http://techtalk.parts-express.com/forum/tech-talk-forum/50560-introducing-echelon/page4
"I number of folks asked for off axis measurements. I have some that were taken of the raw drivers that will indicate how the directivity of the tweeter and midrange match, though I don't have any that I saved with the XO in place. The XO point is around 2khz between the mid and tweet."
2khz crossover. Which is the recommendation I gave in my review. There ya' go. I made a subjective call off objective measurements. Which just happen to line up with what was used. So, I guess measurements tell enough.
http://projectgallery.parts-express.com/speaker.../echelon/
"Crossover points are at 325hz and 2100hz. The woofer to midrange acoustic slopes are approximately 15db/octave, halfway between second and third order. The midrange to tweeter acoustic slopes are approximately 24db/octave."
Turns out, my suggested crossover range (derived from just looking at the measurements) was nearly dead-on to what the builder used. Damn, it feels good to be a gangsta.
I admit it. The blanket comment that "measurements aren't everything" caught me so off guard in a "hard data" sub-forum that I went to do research and completely had my blinders on. It happens. I apologize. Next time, just post in huge, bold, red letters.
I didn't even watch the video, because I felt you wouldn't paint it fairly saying you saw it as unusable.
- Erin
Publish the data and your opinion; how people interpret said isinformation is entirely determined by their individual approach.
