Vintage speaker designs, such as JBLs, encorporated L-pad designs to provide user integration into a specific room environment / preference.
Been playing around with a contour circuit (coil with parallel adjustable resistor, aka one path of L-pad). The full adjustment range is ~3dB, the pic is at approx 1/3rd and 2/3rd rotations.
Yes I agree. I use a miniDSP to both bi-amp and eq (parametric) my speakers. The pic is of a litt'l AN4in. broad-range driver I use with a 300Hz high-pass filter. Once set up as 'neutral' (~flat, with a slight tapering off) I was thinking of just having the L-pad on the drivers...
thinking of a downtown appartment with floor to ceiling windows vs my listening/ living room...
Wolf, I agree in that at these speaker-offs often (to me anyway) it comes down to the integration of the tweeter; just right, too muddled or too bright. With the contour circuit (using L-pad for its varialble resistance across an inductor) vs. using the L-pad as a level control provides a controled tilt (as opposed to raising and lowering the whole driver, which can cause issues at the crossover).
