Getting back into the swing of things.
  • 6-7-8 Khz is sibilance area, and often a problem with some female singers - so I use those in my tuning / tweaking sessions - for instance Bonnie Raitt has a bit of an "ess" problem on Road Tested. If that bugs me, I have to bring the tweeter level down or rework the crossover.
    ani_101
  • How bad is it if I did this with a 1.5 and a .15mh?  They are about an inch apart.  Should have held off the Angry Orchard sampler pack till later ...
  • At an inch apart, you are likely okay.
  • Is the coil on the right an air core standing up on its side or do those straight lines represent an iron core running North/South?
    Air coil standing on edge.  For what it's worth, pear Angry Orchard is meh, the unfiltered apple cider is ok, and that's as far as I got.  Yep, these days I'm a cheap drunk.
