My new tube preamp build
12346»
  • Tubes should never be cool....that means they're off !
    ani_101PWRRYDS79104thtry
  • Tom,
    My very first project with tubes was an Aikido cathode follower preamp, using 6DJ8's that you were kind enough to gift me in that care package you sent about 9 years ago.  It has been in my system continuously for that long because it sounds so good.  I direct copied the main circuit topology from TubeCad's website then scratch designed my own tube rectified power supply.  That's why I was asking if you had anymore NOS 6DJ8's  ;)
  • If I remember correctly you said you had a small stash of them you pulled from some old oscilloscopes.
  • Ahhh - either I didn't know or had forgotten you had built that design. My memory sure isn't my strongest asset these days! I'm guessing the Aikido is a better linestage than my little SRPP 6BH7. I might have to build one for myself now.
    9 years ago? Has it been that long? Man, time flies! I do have a bunch of those 6DJ8s - not NOS, but they tested fine. Do you need a quad?
  •  Good to hear.  Look forward to seeing more of your excellent point to point wiring technique.  Now that you are back into tubes, you will have give your industrial TV-7 the "self-calibration" treatment. :)   Which reminds me, I still have to "self-calibrate" my Heath-Kit TT1.     Then I can start running up matched pairs of power output tubes taking actual transconductance (gm) measurements, and comparing them to the published figures in the RCA receiving tube manuals.
  • Tom, one of the tubes you sent me was a 6dj8.
    Craig, you got some tube for dummies links to the Aikido pre?
  • Let me look Kornbread.  I think all those pages on Tubecad's site are still good.
  • I've decided to add a small 12.6 volt filament transformer to this project so that I can use 12SN7 and 12SX7 tubes instead of the 6 volt 6SN7 tubes.  Cost wise the 12 volt filament tubes are a fraction of the cost for NOS tubes.  Like $6 per tube vs $50 to the moon!
  • Craig - Do you just need a pair of 6SN7's? $50 is ridiculous! There are tons of NOS 6SN7s around. Somebody is seriously hyping these things up just to raise prices. I can sure send you a few of those. Heck, I have a small stack of NOS on the shelf right next me. If you want 12SN7s, I'm pretty sure I have a few of those, but they might not be cosmetic matches.
    I think you need a tube care package - xSN7s & 6DJ8s! I'll see if I still have your address.
    I started reading that CCDA article. Interesting stuff - I might be able to convert my little VTV 6SN7 linestage to that topology. I'll have to see if I can get a B+ of 200v with the PT on that chassis. I never loved the VTV circuit - at least not my build of it.
  • Can I request something on the 6DJ8/6692/E8CC8 family? or rather specifically for the following tubes 6H6, 6n11, 6H30, E88CC, 6922, 6DJ8
    any details on these or opinions?
  • edited November 2019
    Ani, those 6DJ8's are nine pin tubes, not the octal bases that your amp takes.
  • PWRRYD said:
    Ani, those 6DJ8's are nine pin tubes, not the octal that your amp takes.
    yes, not for the tube amp, but for something else on the way.... (pre-amp / DAC). Will add to the thread, as soon as I get it...
  • I'm sure you guys built yours from scratch, but which one of these kits would it be, or which one do you guys  recommend?
    linked to from the Tube Cad Journal.
