I would like to build some speakers for my backyard deck so i can smoke ribs and listen to music. It is an open air deck.  No walls or ceiling.
I need them to be weather proof.
What kind of drivers should i think about to perform in an open air space?  Is this a good application for horns?  I do not know much about horns.
Thanks!
Chad
Since it is 4 pi outdoor space, high efficiency would be good also. Another plus for pro drivers.
http://usspeaker.com/
https://www.rocktheboatmarinestereo.com/html/85947.html
A lot of drivers are waterproof whether they say it or not. Aluminum, poly etc. with rubber surrounds. I would be more concerned with the enclosure. I just use a boombox I built for out on the deck. It gets into the 50 hz range, is small and light.
I've had reasonable success with my Manganese design outdoors. The link is below
https://diy.midwestaudio.club/discussion/1516/manganese-new-deck-speakers/p1.
The woofers are the HiVi M4N, which have a one piece aluminum cone and work well in a sealed enclosure.
