Who's Online (4)
LIMP Data Dump
Well while I still need to design and print the adapters for THD testing, I decided to do a sanity check and run most of the drivers I have sitting around here to make sure they work. I figured I might as well also post up the graphs as a bit of a teaser for the upcoming hard data dump. Here are the drivers I tested of the ones I have lying around (no tweeters yet):
Ok, so the graphs!
  • = Howard Stark: "This is the key to the future. I'm limited by the technology of my time, but one day you'll figure this out."
  • Oh, and of all the drivers above, only one of them was properly broken in. Bonus points if you can tell which one.
    kennykS7910
  • RS125P
  • RS125P
    Looking closer at the graphs, I can see why you'd think that. But actually it is one of the 4 TC6FC02-04 that I actually ran test sweeps on a couple years ago. One of the four is far different, and that is the one that was run.
  • I was guessing based on the age of the drivers
