Safaris - a short order build
edited July 2019 in DIY
Just wanted to throw up some pics of a build I recently started. I need them done in time for MWAF so I didn’t take time to take any build pics.
Woofer: M8N
Tweeter: DA32TX
Cabinet: curved layered HDF sides, particle board top and bottom, plywood back, aspen baffle.
Veneer: ribbon stripe mahogany sides, zebra wood front, top, sides. The mahogany is dyed red mahogany and the whole thing is coated in sprayed amber shellac (needs a few coats yet).
The pics are the one I quick threw together for measurements and offset (which was larger than expected). No crossover yet, still working on that.
JasonPPWRRYDTurn2S7910kennykjhollanderdcibel6thplanet4thtryDanPand 3 others.
  • That looks great! You chose a tweeter that should allow an easier xover than when I did mine. I recommend 1.5kHz or lower, and make it steep and suppressive!
  • beautiful!
  • Those are quite the niceness!
  • Excellent!   Looks like another set of corundum dome tweeters in the <$200 category.  Good luck with getting  the crossover done in time.  Look forward to hearing these next week.
  • I doubt that'll squeak in under $200. Just checked- tweets are $63.79, and $34.86 for woofers. About a buck-fifty under the hammer per channel.
  • edited July 2019
    Thanks guys! They may not be too great by MWAF with such limited time to voice them, if any time. I mocked up a crossover with the measurements I snagged quick the other night and ordered parts, which will be here Tuesday night. I might get time to play with the tweeter resistor and that’s about it..
  • edited July 2019
    Under 200 it is, which is why I chose the combo. These are PE Reg Retail Prices, which is what they go by. $2.70 total under the hammer to be exact. Under 200 is under 200, even if it’s 199.99! B)
  • edited July 2019
    Yeah it’s not the tweeter I’m worried about though. That M8N sounds really snarly with the sine sweep. That cone resonance is very real indeed!
  • +15dB at 2kHz. Ask me how I know....
  • edited July 2019
    Well good luck on completing the crossovers 👍
  • Thanks I need it!
