Xsim question
Is there a way to get xsim to show individual driver phase like PCD?
Thanks
  • Yes.  Under curves select your individual driver.  Then just above the "smoothing" selection there is a check box for phase.
  • Yes in the Fr graph, select each driver under the curves tab and click the phase box. I like to go back to the system curve and uncheck the phase box for the system phase.
  • Select your driver under the curves menu, then check the box.
  • identical time...go figure
  • Ask and you shall receive, thanks much gentlemen
