Check the price tag on the new "graphene" Seas W19:
Compared to the W18 Excel, it has 10cm^2 more surface area, worse frequency response, better corrosion resistance (the only thing the graphene is adding), and double the price tag. It's not the same motor however, having a bit more xmax at the expense of sensitivity. It has higher power handling too, so one can expect it to go louder. Still wouldn't be my first pick if I had CAD$900 to spend on a single midwoofer.
At this point in time, I would bet advancements in woofer technology are coming to a near stand-still, at least with the traditional moving coil/cone approach. So what do elderly companies like Seas/ScanSpeak/Accuton/etc do? They pull a trick like... new material! We solved the problem!
Seriously, though, the Graphene looks like Seas is finally figuring out that whole faraday thing. Not sure it is worth an on-axis response that, were it on a cheaper driver, would result in quite a bit of mild-mannered jeering and eye-rolling. At well over $500/ea I would expect not to have to accept a single compromise in a driver. In fact, I believe we should demand that simple things like the fundamental be well-controlled.
For example, a $19 Goldwood with a similarly poorly designed cone:
Imagine that on a baffle, and the cliff is likely somewhat more pronounced - but this costs $19, the Seas 30x as much.
The Seas is a scam, sorry.
