2019 New Build
1356
  • Very anxious to see those finished. Beautiful veneer.
  • Did some cutting after work today. Relieved the enclosures of their corners to make room for the Wenge inlay trim.
    jhollanderTurn2GowaNicholas_234thtry
  • Bet it looks better live. Pretty nice in the photo.
  • Nice color combo
  • Thanks, that's kinda what I was going for. I like to use the wood species to create the tone of the build.
  • Started installation of the corner trim...
    Nicholas_23
  • One down, 3/4 of one to go...
    GowaPWRRYD4thtry
  • Yep. Wenge can be extremely irritating. Not so much a sensitizer like rosewoods and such, but _very_ _extremely_ painful splinters, maybe the worst I've ever experienced. I recall many tiny, almost microscopic, splinters that hurt badly and looked like they were infected within just moments (can still recall the pain some 35 plus years later).  And the dust does a number on the mucous membranes for certain.
    Otherwise it's a wonderfully beautiful wood and quite benign when fully worked and finished. :anguished:
    Wolf said:
    Another note on Wenge- It's a strong skin irritant, and I would recommend a respirator. If at all possible, avoid getting splinters in your fingers. My uncle works for a cabinet maker, and he is very opposed to working with Wenge.
    powered by beer
  • edited April 2019
    powered by beer
  • Hi Tom.  Good to see you around here again.
  • After Johns mention on how bad that stuff is, I invested in a cartridge style respirator. So far no nasty splinters 😁👍
  • Always fun to pop in when I can, Craig!
    Hope all's well.
    powered by beer
  • So far no name has popped up, you guys feeling anything?
  • edited April 2019
    Balise = Beacon
    Balise de musique = Music Beacon
    Conducteur = Condutctor
    Bravo
    Hourrah
    Applause
  • Good food for thought, I wonder if something Saturn related is in need?
  • Moons of Saturn, it has 62 (just don't use Fenrir, ;) ): https://www.google.com/search?source=hp&ei=wP7FXLWzCdD2swXmx66YCg&q=moons+of+saturn&btnK=Google+Search&oq=moons+of+saturn&gs_l=psy-ab.3..0l10.93.3539..4978...0.0..0.860.4951.0j1j5j5j2j0j1......0....1..gws-wiz.......0i131.-66vGnlCRQY
    My pick of the moons- Epimetheus. Epimetheus as a word actually means hindsight. Being these are open-back, that makes perfect sense to me.
    kennyk
  • I was pretty sure Titan was a subwoofer name somewhere already. What didn't know was that some of the Saturn model lineup was actually named after Saturn's moons. S2 for example.
  • ACI Titan is the sub I think you're remembering? It was one of the early high quality DIY subs, my teenage self used to dream of building one
    I just so happen to have two ACI DV12 drivers if you're interested.
    BrannigansLaw
  • Maybe SXO Titan or the other way around, Titan SXO?
    Thanks, but I just this weekend picked up a third Rhythmik DS1200 servo kit, so I'm set for subs I think :)
  • Got the router set up and ready for countersinking the woofer....
    Silver1omokennykR-Carpenter4thtry
  • Can't say I am a big fan of working with Wenge. It does create a good looking contrast tho.
    What are you finishing with? Wenge is very oily and can lift lacquer after a period of time.
  • Haven't got that far yet, prolly some oil finish of some sort, maybe poly??
  • Oil or poly sounds about right. Wipe the surfaces good with acetone before applying the finish. Natural rosewood oils as well as wenge on some occasions will react with the poly.
  • My wenge veneer has sprayed Lacquer.  Lets see how long it lasts.
  • How long has yours been, John?
    I learned the acetone trick on an earlier project, good tip to know.
  • About 4 months.  I used denatured alcohol.  The wiping part was the problem I mentioned earlier.
