Initial planning/design for a high efficiency design.
Got got some ESS Hiel tweeters last year, and recently got a pair of Dayton PM385 woofers when they were DOTD.
https://www.parts-express.com/dayton-audio-pn395-8-15-neo-series-pro-woofer-with-4-voice-coil-8-ohm--295-044 That's listed as 97dB SPL at 2.83V/m, so lose about 1.5 dB for BSC, and now we're at 95.5 dB 2.83v
Now I need to choose a mid(s).
I'm leaning towards a MTM with 2 FaitalPro 4FE35 each side.
https://www.parts-express.com/faitalpro-4fe35-4-professional-full-range-woofer-8-ohm--294-1124 I like the Neodymium version, but can't see how it's better.
The 4FE35-8 is listed as 91 dB/w, so 2x should give about 97 dB/w (in this case, is that 97 dB 2.83v ?)
But minus 1.5 dB BSC, and we have about 95.5
Or I could get something like a Beyma 6 inch mid. and do a classic TMW
Any suggestions for "wow that's great" sound quality, low distortion and high efficiency mids?
re: JH - yeah, I've heard good things too. Ready to experience the fun.
B&C, Beyma and FaitaPro are top of the stack. Reasonable cost, low distortion, and smooth(ish) FR.
PM180 is a good idea. Could even use the PS180 or the new poly-neo driver PE peddles for car audio.
The difference in the NeFeB vs ferrite is the Neo will be a lower HD driver inherently. Studies have been done.
As far as my ballpark BSC, I figure crossover woofer/mid around 300-400, so half of a 3dB BSC "should" be handled by the woofer, and half by the mid. <shrug> should work.
I'll look at the suggested solutions, and maybe even order a few from PE to listen and test, and send back the losers.
http://www.usspeaker.com/beyma 5MP60n-1.htm
get close (maybe best to look at ~240+ low for mids) to your stated low range (and re the low end side, down below 300 you are in a very low ear sensitivity range for crossover concerns, and agree with dcibel comment re BSC overlap for woofer duty) and depending how high you're looking to cross to tw...
you could possibly keep the crossover out of the 1500~4500 highest ear sensitivity range... (and for those concerned about high freq dispersion, could be much, much worse, you could be considering head-in-a-vice $250g electrostats.... ha)
and these may be the 6.5's you are looking at ?
http://www.usspeaker.com/beyma 6B30P-1.htm
fyi I have not listened to these, just replying per your post info on stats, and I'm a bit biased towards beyma (good experience with my 12's), and a fan of employing broad range drivers as midrange+. And fav's are Audio Nirvana's; https://commonsenseaudio.com/an6.5cfspecs.jpg
here are the 6.5 AN's, as employed in a two way (biamped / active minidsp) clearly capable of 20g Hz (5db verticals, approx 1 meter)
And I will accept the expert advice to forget about bass with this guy. Only with a sub if running TM (which might be the change down the road.) But I don't really see any other competitors in this class, at this price. ($170)
http://www.usspeaker.com/beyma%206g40nd-1.htm
Thanks for all the advice, guys. My first foray into this area.
A friend some years ago had a VOT, and it was a lot of fun, if not exactly flat.
The dynamics were incredible.
I'm hoping that this will have some of those qualities, and better FR and distortion to boot.
I'm working right now with a Tangband W4-1320 MTM. Little 4" guy goes out to about 16Khz flat.
Phenomenal full range driver.
Best regards,
http://www.usspeaker.com/beyma%206CMV2-1.htmhttp://www.usspeaker.com/beyma 6CMV2-1.htm
How about PRV? 6MR500-NDY or 5MR450-NDY:
https://www.parts-express.com/Search.aspx?keyword=ndy&sitesearch=true
Dustcap is ugly, but that's easily fixed.
Hmm, most of the PRVs have a 5 dB notch between 1k and 2k. That indicates a cone/surround problem, right?
And it would show up in a ZMA plot, correct?
https://www.madisoundspeakerstore.com/pro-sound/audax-pr170m0-6.5-midrange-100db/
https://www.madisoundspeakerstore.com/approx-4-midrange/scanspeak-discovery-10f/8424g-4-midrange-8-ohm/
I'll probably order one of each (and the PM180) from PE and run my own tests.
I have been noticing that some of the nicest flat FR, low distortion Pro 6" often have 1mm xmax - have to run the models to see if that will be a problem.
I definitely agree that it is a sound that could be called dead, or perhaps less negatively called sterile or flat. That said though it is also very uncolored and clean. Just depends on what you’re after I suppose.
Sorry for the tangent, back to your regularly scheduled thread.
Honestly, I'll need to run the box models before purchases, but I am back with a Faitalpro 4FE35 4 inch MTM on the top of the list. I don't need or want small club volume, just some effortless strong dynamics for home use.
I really like that Faitalpro gives you specs for both xmax and xdamage.
From the bunch I tested, the Faital Pro's had the most excursion potential (all three different models).
The one with the least excursion was the 18 Sound 10NDA610, but that was expected since the listed Xmax is only ~2.5mm. Like the Ciare NDH 10-3, it has a black, rubbery dampping compound. The Ciare has it in the valley of the front of the m-roll cloth surround, where as the 10 NDA610 has on on the backside of the m-roll surround, on the underside of the outermost half-roll.
This Ciare I pushed too hard during break-in (even though I was within Xmax), and I think you can see where the cone edge started to slightly buckle. I ended up putting a very thin fiberglass mesh on the backside along the entire circumference where the crease started to happen for added support, even though they will never see that level of excursion again. That black damping compound is what limits the excursion quite a bit on this speaker, even though the voice coil overhand is there.
This is the 18 Sound 10NDA610 backside shot. Looks/feels like the same kind of damping compound.
First, I noticed a comment by Jeff Bagby for someone's pro woofer IE: "nice high QMS".
Then I was reading a Tony Gee design/writeup for the Calpamos:
Quote: " When choosing suitable pro drivers for a domestic hifi loudspeaker there a few parameters that have to be taken into consideration. In regards to ..... midwoofers we are looking for a driver that has low mechanical losses, low moving mass .... Low mechanical losses are important when playing music at low sound levels. If the losses are too high you get a speaker that doesn't "open up" unless it is played loudly.....
One way of checking if a driver has low mechanical losses is to look at the impedance peak at the resonance frequency. If it is low and wide then the driver has high mechanical losses, if it shows a high and narrow, sharp spike, then we are looking at a woofer with low mechanical losses. "
End Quote
TG also mentions a high BL/MMS number for good midrange detail.
Top of the list: QMS BL/MMS Xmax Le Fs Impedance peak
Beyma 3FR30ND 9.5 2.4 4.5mm .3mH 72
Beyma 4FR40ND 10.8 .93 3.0mm .2mH 63
Faital Pro 4FE32 4.9 1.23 2.7mm .18mH 62
B&C 3.5NDF26 8.8 1.27 3.2mm .26mH 70
Looked at this this way, the Faital Pro 4FE32 doesn't have a Qms to match the other candidates.
