Big discounts on Heil AMT's
2
  • RJ , how goes the battle?
    Working on it! Initial problem, I had V2 of the OM test tracks, and I wasn't about to wait for
    3 days for PE to send me a new disc. Went into OM and checked for update, and there was
    the new SW (5.02) and Test Tracks with the 50Hz test tone references.
    Now for some measurements!
    Gowa
  • Hmmm, setup was pretty easy, but I was getting about 120dB for 2.83 AC Volts.
    Read the notes, ok need use 2.00 ACV for a 4 ohm driver.
    So I recalibrated to that voltage. Switched to Track 2.
    Getting the characteristic 5-7 dB shelf from 2k to 10K, but the main part of the shelf is
    at about 115 dB one meter. Using some cheap 20 uF caps to protect the Heil.
    Pretty sure the meter is accurate, the amp I'm driving shows about 1W peaks for the sweeps.
    (Head scratcher)
  • If you want sensitivity at 2.83V, use 2.83V regardless of impedance, but just realize that this is about 2W for a 4 ohm load.
    120dB is uhh, a bit much. What are you using for an amp? And for a meter while were at it? Do you have a 5-10W resistor in the 4-20 ohm range you can attach to the amp when setting the voltage, just to be sure the amp isn't doing weird things when there is no load.
    You can do this test backwards as well. Instead of setting the amp at 2.83V and measuring the driver, just measure the driver as you normally would, adjust the amp gain for 85-90dB or whatever you're comfortable with. Then play the 50Hz tone and measure the amp output voltage. From here you can do some math to figure out how many dB to shift your measurement for a 2.83V result.
    Good suggestions - I'll give that a try tomorrow along with a couple of tests at 2.83v with other speakers I've got with pretty much known sensitivity. Also, find my Oscope and check the voltage with that.
    Amp is vintage Kenwood KM-208. Pretty clean, extended and powerful. Tones played from Volumio on a RasPi with PiFi DAC.
    The real unknown in this is the new meter (Surpeer AV4 autorange, 4 1/2 digit, true RMS, reads Frequency.)
  • edited January 2019
    If you want to determine if there's any change on your amp output with or without a load, just lower the voltage and use a driver that will be fine with a 50Hz tone, so not a tweeter.
    FWIW I haven't used the test tone CD in years. The software will generate the tones, so I just run a cable from my computer. Under the config menu, the first item is "play from soundcard". When you are in the SPL/Spectrum Tab, there is a tone generator available in the config menu for the 50-60Hz tone.
    Here's a calculator for working out change in SPL over distance. Note that this doesn't account for boundary reinforcement, so for indoor measurements this calculation is accurate for gated reflection free measurements. I wouldn't use this for a subwoofer.
    For S&Gs I wanted to see if I could determine the sensitivity of a speaker using Omnimic and an arbitrary distance and voltage. So I took a speaker, set up the mic at 60cm, and set the gain on the amp until the frequency response was about 70dB. I used the calculator linked above to determine that 70dB@60cm is equal to 65.56dB@1m. To confirm this math, I backed my mic up to 1m, and sure enough we were at about 65.5dB.
    I then played a 55Hz test tone from the Omnimic tone generator, and measured a whopping 0.338V at the amp output, with the speaker connected, and to be sure, I disconnected the speaker and measured the same voltage exactly.
    So 65.56dB@0.338V@1m is where we are at now. Math is hard, so we'll just use another website calculator to sort this out as well. From the same site:
    We determine that 2.83V is a 18.45dB gain from 0.338V, so my speaker sensitivity then becomes 84dB@2.83V@1m. I expected 84.5-85dB, so we're pretty darn close.
    In any case, another fun piece of information, is that the 120dB measurement you took above, using the online calculator, is more like a 50V measurement if we expect a 95dB sensitive tweeter, so your meter would have to be off by miles to get that sort of output, and probably fry the diaphragm in the process (and melt your ears). The only think I can think to add is to make sure your cal file is loaded. I have an old V1 omnimic that uses a code instead of a cal file, but if I don't enter the code when I install the software, I'm off by about 5dB for SPL.
  • @dcibel
      -- great tips, and good links, I'll dive into it tomorrow.
    Dug out my (little CN) scope, and hooked it up while the source and amp were setup to deliver 2.00 ACV with a 50 Hz sine wave. I hadn't used this scope very much, so I diddled with it until I had a stable waveform covering 3/4 of the vertical screen. At .1v  per division, it was about .56 v PtoP, in fact that's what the display read. So then I look at the probe, and sure enough, it's a 10x probe, so I've actually got 5.6ACV peak to peak, which means about 2.00 v RMS.
    I've got a couple of other speakers to test, I'm using some RS125Ps in 4 L boxes as stands.
    Hopefully, the SPL delivered by them at 2.00v will be more in line with the desired results.
    Thanks again for your assistance.
  • I take it you are using 2V to match up with the sensitivity @1W used in the ESS specs? If that's the case, keeping in mind that these have a pretty much flat line impedance at about 3.5 Ohms (going off of Nicholas' measurement), you'd be looking at 1.87V for 1W. Not that it matters much, as long as you record the voltage used and mic distance we can get a fairly accurate calculation of SPL for any voltage.
    I double checked everything, and all was correct, so the only thing left was to install OM on a different computer.
    Results were at least pretty close to what was expected. Drive was 2.00ACV RMS, monophonic short sine sweep.
    Ran 2 tests, dipole and monopole FR was  bit different for each. Not seeing the stated 95 dB sensitivity.
    Used a 20uF cap inline to protect the tweeter.
    Gowadcibel
    Excellent, glad you got it sorted out. If they mislabelled the 95dB@1w and actually meant 95dB@2.83V, that would be pretty on the money for peak sensitivity. The downside of that sensitivity rating is that it's not useful information if you intend on a normal crossover in 1-2kHz range.
    Just another thing to add, that I found when measuring my AMTPRO drivers was the lack of vertical directivity actually made measuring them indoors very easy, since there was next to no reflection from the floor/ceiling. Looking at your measurement, I think you could increase the gate to a bit more than 5ms without much artifacts in the response.
    It's a very usable response anyway, there's some info linked in the thread about these tweeters over at DIYAudio from a German site that claims to have found the cause of the peak at 5kHz and some added felt/foam to strategic locations to fix it.
  • I'll look into those links, maybe try some things and post results if anyone is interested.
    Looks like the Heil ESS tweeters are going to be $160 / pair long term.
    $160 / pair? :o
  • Pretty speaker, is that a Duratex baffle? =)
  • I think it's leather.
    Gowa said:
    $160 / pair? :o
    Ver 1 = 170, Ver 2 = 160, Ver3 = 150
    I can't see how they are making money at those prices, but they will surely gain some market share.
  • Are you sure that's per pair?
    keen eye. yeah per piece. Back to normal...
  • Ah, Volent! I've wondered long about how those sound with an Eton 12", ATD midbass, Heil upper mid and whatever tweeter that is.
  • I think the tweeter is LCY.
    Build it and "they will come"
  • Hah- You're looking at a lot of money there. $600 for the ATD, if you can find it. ~$200 for the LCY (thanks, Leon!)), about $700 for the NOS Eton hexacone woofer, plus whatever you get the Heils for. I'm guessing that is easily $3.5k in drivers alone.
  • edited March 2020
    Did you guys get around to building with the Heil tweeter?  How did they sound?
    Still on my shelf (sad). I design and build so slow.....
  • Yeah, what was it, 2 years ago about this time of the year, they had the big blowout sale?
    Snagged 2 pairs, still on the shelf waiting on my sorry ass.
    Pairing with that 10FE200 should be heaven!
  • Hard to say, but I think those 2 will work. The 10FE200 looks like a true 96 dB passband, but you will lose 3-4 dB for BSC.
    Unfortunately, it's hard to get accurate sensitivity specs for the ESS Heils.
    This may help:
    Listed as 96 dB here:
    https://adelcom.net/ESS HEIL Tweeter Replacements.htm
    Listed as 92 dB here:
    https://diy.midwestaudio.club/discussion/873/big-discounts-on-heil-amts#latest
    Unfortunately, both specs at 1W/1M - but the ESS Heils are also 4 ohm drivers listed as 1W/1M,
    so the specs compare directly. I'd say go for it. I actually modeled the 10FE200 with the Heil
    a few years ago, what worried me was the low end of the woofer. Looks like a big rolloff under
    about 100Hz for it, but it's unclear what the measurement was. Probably an IEC baffle without
    nearfield spliced in, so bottom end may be good. Certainly is inexpensive...
  • You could go active and not worry about sensitivity.
  • edited November 2020
  • For years I've thought about a Minidsp HD - I've got a very nice 6 channel vintage amp, so setup costs would be minimal.
    ani_101
    I've found the use of the miniDSP as an active filter btwn woofer and the top, and passive for the mid / tweeter, works well as I've leaned towards 3ways. It then of course can additionally be employed (or overused...) as contour / eq networks. I.e. for fans of a BBC dip, and adjusting / testing and finding the right crossover point (and slopes) between the mid and woofer… But best to focus on attenuating vs. amplifying (peaks / troughs).
    Nicholas_23
  • When I measured the 8FE200, the Fs was higher than spec as well for the quad I had.
