Wazup wit dis
f(s) = 72.67 Hz
Q(ms) = 9.257
V(as) = 10.33 liters (0.365 cubic feet)
n(0) = 0.62 %
M(ms) = 12.24 grams
R(e) = 6.93 Ohms
Q(es) = 0.614
SPL = 89.99 dB SPL 1W/1m
C(ms) = 0.39 mm/N
Piston Diameter = 132.1 mm
Z(max) = 111.37 Ohms
Q(ts) = 0.576
L(e) = 0.150 mH at 10kHz
SPL = 90.61 dB SPL 2.83 Vrms
BL = 7.94
  • .....and
    f(s) = 49.12 Hz
    Q(ms) = 6.463
    V(as) = 22.72 liters
    n(0) = 0.55 %
    M(ms) = 12.18 grams
    R(e) = 6.96 Ohms
    Q(es) = 0.469
    SPL = 89.48 dB SPL 1W/1m
    C(ms) = 0.86 mm/N
    Z(max) = 102.89 Ohms
    Q(ts) = 0.437
    SPL = 90.08 dB SPL 2.83 Vrms
    BL = 7.47
  • Qms is MUCH higher on the first one, and meas Vas reflects that, along with a higher Fs. Are they broken in?
    I'd flex the suspensions, and remeasure.
  • Both drivers were Dats measured cold out of the box. The first one is Kevlar and the second is paper. Pretty high spl on both though. Big Rival Magnets as well.
  • These are OEM drivers. I did a bit of flexy with the cones and this is what I have. They indeed have the 120 mm magnets.
    Rival Acoustics RO182-OKL-08 (OEM) Same basket as Wavecor
    Kevlar cone with Bimax spider
    f(s) = 49.12 Hz
    Q(ms) = 5.205
    V(as) = 17.90 liters (0.632 cubic feet)
    n(0) = 0.42 %
    M(ms) = 15.46 grams
    R(e) = 7.00 Ohms
    Q(es) = 0.476
    SPL = 88.38 dB SPL 1W/1m
    C(ms) = 0.68 mm/N
    Z(max) = 83.50 Ohms
    Q(ts) = 0.436
    L(e) = 0.148 mH at 10kHz
    SPL = 88.96 dB SPL 2.83 Vrms
    BL = 8.37
    Rival Acoustics R176-CPB-08 (OEM)
    Paper cone with Bimax spider
    f(s) = 39.03 Hz
    Q(ms) = 5.329
    V(as) = 24.38 liters (0.861 cubic feet)
    n(0) = 0.32 %
    M(ms) = 17.98 grams
    R(e) = 7.06 Ohms
    Q(es) = 0.433
    SPL = 87.14 dB SPL 1W/1m
    C(ms) = 0.93 mm/N
    Z(max) = 93.88 Ohms
    Q(ts) = 0.401
    L(e) = 0.147 mH at 10kHz
    SPL = 87.68 dB SPL 2.83 Vrms
    BL = 8.48
  • If those are the same 2 drivers, you can see it is an improvement over the previous grit.
