Latest project - a Dayton MTM
It only took me almost 8 months to finish this build but I finally got it done! I wanted to try out the TCP115 woofers in a MTM design (my first one) so I paired them with the ND25FA tweeter. Decided to use some of my Suar wood I had lying around and tried to integrate the live edge of the wood into the design. It turned out ok but would be more noticeable if the baffles were thicker. Both baffles are from one piece of wood with only about 2" missing from the middle of the piece. The rest of the cabinets are 3/4' BB. Pretty simple 12db electrical filters on both drivers with a zobel on the woofer and l-pad on the tweeter - crossover point was at 3k. Box is .25cf tuned to 58hz by a 2"x8" port.
PCD response,
In room response at 2ft,
Glamour shots =)
Some build pics,
A decent little speaker for what the drivers cost - and a surprising amount of low end response from a couple 4" drivers. I did have a few oops while making these - one you can see in the last picture here around the speaker opening and the other is a big gouge on the back of one of the speakers from when I was putting the round overs on the cabinets. Now that the rainy season has started I might actually start on some other projects I have been wanting to do for a while now B)
jhollanderPWRRYDD1PP1NJasonP
  • Nice piece of wood on those baffles, good job.
  •  Fun little project!
    I totally dig the mitered corners - I usually wimp out and do a butt joint, but
    of course a miter is so much better.
  • But I have to ask, where do you source your ply? That is very nice ply. #askingforafriend
    rjj45 said:
     Fun little project!
    Thanks guys!
    Rjj - I prefer the mitered corners when I use the ply, and a small round over usually takes care of any gaps =)
     Jason I get my BB ply from a local supplier called Windsor Plywood. It might be a bit of a drive for you as I live on the west coast of Canada :p
