ok, so I am trying to squeeze a whole lot of woofer into not a lot of box. A EBS tune gets me nice an low, but the port is very long - Even getting the port diameter small as low as 1" it is still very long - increasing it to 2 gets me to almost a meter for the port length.
So I started looking into PRs big and small. The PR seems to get me nearly there - the tune is not as low as the port, but acceptable. The problem is the amount of weight I need to add to these tiny PRs. Is there some rule or thumb or some way to know how much weight is too much?
I am looking at the Dayton 6.5 inch, the Peerless 5.14 inch and the Dayton inch" PR. Are there any other cheap 5" - 8" PR out there that i should be looking at?
Thanks and Regards
Ani
http://bit.ly/2cwEBff
I think if someone were willing to execute and document this experiment, it would be a feather in their cap...
When I tore apart those little TV speakers they just had a rubber surround glued to a metal plate as a PR. You can buy surround kits. J. Bagby started a PR design but don't think anything came of it (?) I don't think he used a spider either.
So a complete DIY PR would be a cool project. Any good reference materials around?
