I haven't used any Goldwood products in some time. Wondering if any of you have personal experience with this woofer. If the specs are accurate, then I have a beautiful pair of golden oak cabinets that these will work great in. The idea is a low budget, early 80s 3way build. I will have to make new baffles, but no biggie there. 1.68 cubes gross.
http://www.parts-express.com/goldwood-gw-10pc-4-10-heavy-duty-woofer-4-ohm--290-322
I will take another look at the sd270.
Posted Tested
RE 3.8 4.1
Fs 43.1 36.3
Qms 4.25 3.84
Qes 0.446 0.412
Qts 0.403 0.372
Vas 1.15 1.22
SPL 92.7 87.9
Mms 69.7 93.1
I am curious as to the Mms difference. The higher value does account for the lower Fs and Qts numbers but what is the difference in the original cone and this batch? Hmm perhaps they weighed the cone prior to attaching the voice coil, surround and spider? Don't know but it would kind of fly in the face of what someone was recently propagating "over there".
Still not horrible. I'll still sim it later and I think it is a viable yet unorthodox option at this point. Just something different.
For the mid, I am considering the Dayton pa130-8. Again, something different but keeping in line with the 80s throwback look.
Mms necessarily includes X% of the spider and Y% of the surround, and is subject to gluing process variations between spider to cone, voice coil to cone, and dustcap to cone.
That being said, the T/S are far better than I was expecting to see. I believe Ben had measured his pair of the 6.5" from that series to be wildly different between the two samples as well as compared to advertised. Then again, process variations will affect smaller drivers disproportionately.
