My new Open Baffle Project
24
  • I was able to circle back around to this project last night.  I've been spending a lot of time lately getting my Mustang ready to go back to the drag strip (it's been 9 years since I last raced).  Anyway I had the house to myself so I used that time to take a bunch of tweeter measurements with my different test baffles.  I took on axis, 15 deg, 30 deg, and 45 deg off axis (horizontal) measurements.  The measurements show the stock plastic faceplate front flush mounted was the clear winner.  Those measurements were very smooth and actually improved as I moved further off axis.  Second place went to the straight 45 deg chamfer, 1/2" deep guide.  It looked fairly similar to the stock faceplace down low but got pretty nasty above 10kHz.  Last place was the 1/2" roundover guide.  It displayed a 6 dB dip at 5kHz and a wonky top end.  I did not try to measure the tweeter front mounted flush with no faceplate as Ben plans to.  So I can't guess how it would fare.
  • Are you hitting the US Nationals this weekend?
  • Man I would love to, but it's my daughter's 9th Bday party this weekend.
  • Dig, I'll be there tomorrow. 2.5 hour drive makes it an easy trip
  • Have fun Eric!  What's the weather supposed to be like?
  • Well everyone bailed on me, so I didn't go. :( Ended up working out in the garage, more shelves and putting junk on them.
  • Router work on the poplar baffles is complete.  These "test" baffles turned out nice enough I think I'll give them a good sanding and apply some sort of finish.  That way I have plenty of time to take more intensive measurements and design the crossovers in time for DIY Iowa!
  • Pictures to follow after the finish.
  • So it's stock faceplate flush mounted?
  • edited September 2018
    Correct, stock plastic faceplate.  Front mounted tweeter and mid, both flush.
  • Wolf and I were talking about how the faceplate might be buzzing and adding to some of the published distortion measurements.
    I'm looking forward to hearing these in Iowa.
  • Hmmm?  I'll look for strange distortion.
  • I'm going to attempt to stain these baffles red mahogany.  I bought some wood conditioner that will hopefully stave off the blotchiness poplar supposedly has.  I'll test on scrap pieces first of course.
  • I did some sample pieces after work.  The Minwax conditioner followed with red mahogany stain didn't turn out very well at all.  Still very blotchy.  I blame it on the extremely marginal quality of pretty much every Minwax product I've evwr used.  The straight shellac looked pretty nice but it never lays flat and requires coat-sand-coat-sand-coat.....  The BLO really popped the grain and color and will look great after it fully cures and then top coated with some gloss lacquer.  So I think that is what I will use on the baffles.
  • BLO?  How do you use it?
    Boiled Linseed Oil.  I just apply it right out of the can with an old white tube sock.  Let it sit and soak in for 10 minutes or so, then wipe off any excess with an old t-shirt.  It can be handled the next day but I wouldn't put a top coat on for at least a week.  A fan helps speed the curing process.  It's not a look everyone would like because it adds an amber hue to the wood.  I personally like that look though and it does make the grain patern really show.
  • Craig are you using sealcoat as is out of the can? You can dilute it with denatured alcohol and apply thinner coats if you want it to lay a little flatter. I usually just do a quick hand sand with 320 to 600 depending in satin/semi/polished (my waterbassed gloss poly likes 600 grit). It dries so fast the streaks from the applicator usually remain.
  • Aha ...  isn't that the stuff that catches your rags on fire?  Used Danish Oil on boys Picos.  The look was ok but the feel was what set the wood off.  Do you also 'sand the blo in'?
  • I think if you did a large project like a whole set of kitchen cabinets and threw all those rags in a garbage can they could catch on fire.  For a speaker/amp project I only have one small application rag that is fairly wet and two or three wipe off rags that barely have any BLO on them.  Still... I'm very careful to lay all of them out flat on the concrete floor and away from anything combustable until they're dry (basically the next morning).
    I don't sand the BLO in.  I only sand the wood up to 220 grit, clean it well, then apply with just an old sock moving in the direction of the grain.
    I like this finish.  I've used this finish on a couple of speaker baffles and a couple of tube amp/preamp cases with good results.  YMMV
  • Any pics? I’m getting bored looking at my hammer collection    =)
  • One old time trick was to sand in BLO as a small grain filler.  I've tried it twice and it's a muddy mess.  First it takes forever to dry, once it does it obscures the grain and diminishes the depth.
    BTW, BLO is great finish on wooden handle tools like shovels and hammers...I use it on my workbench top
  • BLO...  hammers...  you listening dynamo? ;)
  • Here are some cell phone pictures.  Here is the same board side by side, both sanded up to 220 grit, one bare and one with a coat of boiled linseed oil.  No top coat.
  • Here are the prototype baffles with drivers installed.  If I like how they sound I will eventually make new baffles out of some nice species of wood like walnut or cherry.  Still these don't look too bad in poplar.  A couple coats of clear lacquer will improve their look.
    GowajhollanderS7910Bryan@MACNicholas_23kennyk
  • Bring on the bass bins.
    Gowakennyk
  • Hmm, missed the disussion (if any) about the waveguide for the tweeter.
    What's the deal?
    Love those TB 1320SIF bamboo, I listened to them full range for about a year,
    and may use them in a new 3 way.
    Nice look with the poplar. I'm a big fan of all Tung finishes. I've had some problems
    with other finishes.
  • Those are looking great Craig! Can't wait to hear them next month.
  • Those really look great Craig! Good choice on the finish.
  • Thanks for the compliment Nick but when you look at them closely in person they aren't exactly perfect.  Anyway, I took a good sniff of them after work tonight and there is no trace of the linseed smell (ie it has cured).  So I'm going to go ahead and top coat them with clear gloss lacquer, sprayed from a rattle can.  It's the perfect weather right now to spray and there is a very light breeze in the right direction to move the fumes and any over-spray out of the garage and away from the Mustang.
    What's the deal?
    I removed the factory plastic faceplate and bolted the tweeters to the backside of several test baffles that were different "wavguide" profiles and size.  None of those prototypes measured as smoothly on and off axis as the factory faceplate.  So I stayed with it.
