Any ideas on how I can countersink these bolts into the baffle? I already drilled the 1/4" holes in the baffle for the bolt to pass thru but looking back I think I should have drilled the countersink part first then the thru hole. The bolt head is just over 5/8" in diameter. I have tried using my forstner bits and flat wood bits but they don't work well because I have already drilled the 1/4" hole so they can't center themselves on the small tip on the bits.
