Another question - is there any alternative for sealing speaker boxes to make the joints air tight? I have been using silicone caulk, but it is messy and smelly and it needs over 24 hrs to air out. It is good in the summer, but winter time really painful to use inside the house. Any better alternative to sealing the boxes from inside - doesn't need to look pretty, just seal the joints.
+1. I think my woodworking breakthrough came when I started cutting the same dimension of every panel at the one time
Also, check your fence for 90deg to the table. I bought a little $20 digital angle gauge that you can zero on your tablesaw top then attach to blade or fence to verify it's 90 deg. It saves alot of time.
