Interesting New Tymphany Drivers
2
  • The tweeter used in Cabrini Redux was just fine, the other GRS dome is garbage.
  •  JasonP said:
    Thanks for the info, Jason.  :3   I put a pair of these on my MWAF shopping list for July.
  • Has anyone taken distortion measurements on the Peerless DA25TX00-08 (Corundum) tweeter yet?  Thinking about using it in the InDIYana 2019 theme challenge, but I was hoping one of you guys had thrown it on a test bench.
  • I bought the 32mm, and haven't even finished the Tandems yet.
  • I have the 25s for Indy also.  I dats them and they matched factory as I recall,  but nothing beyond that.  Cutting wood today.  I will try some quasi low order slopes with them.
  • I haven't jumped on these yet, simply because I have so many drivers around the home now I'm selling them dirt cheap at events. I really do want to see some tests and hear them, so hopefully at an event this year? I was kind of surprised no designs showed with them at Iowa 2018.
  • I'm enjoying a relaxed build process so I was in no hurry
  • Pulled the trigger and got them today.  They are pretty impressive.  Big magnet, crazy heatsink, dome and surround look good quality and even the grill isn't bad.  But what's up with the flimsy faceplate?  Even the packaging was high quality, so I don't get why they opted for a 1.5mm thick sheet metal faceplate, especially when it is 122mm in diameter and only 4 mounting holes.  So far it looks like a lot of tweeter for the money, but I'd gladly have paid another 5 bones for sturdier and better looking structure.
    I'll try to take some distortion measurements this week/end.
    Dan
  • So I got a chance to take some distortion measurements today of the 25mm corundum tweet.  Not disappointing at all for a 25mm, $54 tweeter.  These were taken at 5", so drop the level about 18dB to compare to 1m measurements.  No baffle for these measurements, just propped up about 6" off of a carpeted floor, firing upwards towards the mic, so FR is useless in these plots.
    Looks like the larger domed Usher has the advantage between 1kHz and 3kHz, but above 3kHz, it looks the DA25TX has the advantage.  2nd order is still higher as would be expected from a smaller dome, but the higher order stuff is almost non-existent above 3kHz.  Looks promising and with that giant heatsink, should be able to get after the volume knob without too much change in performance.
    One thing of note during this test - the signal was unfiltered as I always do when measuring domes, and the DA25TX dome was moving A LOT.  I'm not sure if it has a larger chamber or less restrictive suspension or what, but I've never seen a dome tweeter move this much - not even the LD22, which would need to in order to hit similar SPLs.  Not only did it sustain no damage from this excursion, but it didn't even sound distressed while doing so.
    Peerless DA25TX00-08 Corundum Tweeter
    And the Usher 9950-15, a known distortion champ, for reference.
    PWRRYDJasonP
  • DanP said:
    ...No baffle for these measurements, just propped up about 6" off of a carpeted floor, firing upwards towards the mic, so FR is useless in these plots.
    I wouldn't say that FR is useless. The harmonic information in Omnimic isn't shown relative to the fundamental, so the frequency response is important information to understand the plot. In any case, the DA25 is a great performer, I am actually more excited for the DA32 though, a lot larger dome and still manages a resonance > 20kHz. I know of a few 25mm domes that can't do that.
  • I'll post the HD on the 32 when I take it in the future.
  • Me too on the 32.  It'll be a while before I get the baffles completed though.
  • You have a pair too? For what with?
  • MTM's with R176-CP-08.
  • They are going in my repurposed curve-sided towers I built for the Agendas project.
    Yes, you're right - I meant for modeling.  I am more excited about the DA32 as well, but the 32 was over budget for Wolf's 2019 theme challenge, which I will enter this year come hell or high water.  Been too busy these last few years to build anything, but no more excuses.  Looking forward to some distortion measurements on the DA32 from you guys.
  • So what about 3d printing a decent faceplate?  There are a few of use who could use something a bit more beefy. I'm already planning to paint my faceplate and woofer frame.
  • I'm already planning to paint my faceplate and woofer frame.
    Purple with glitter?  Just kidding John :)
    jr@macS7910ThumperTomrjj45
  • Yes there is glitter= metallic= metal flake= George Barris, king of kustom.  Not purple however.
    jr@maccssaudio1ThumperTomkennyk
  • Spent the last few nights listening to the Peerless DA25TX00-08 (Corundum) and I really like this tweeter.  The cheap face plate aside, I think this meets my need for a detailed resolving tweeter without being harsh.
    The off axis performance (no x-o) was the best I've measured.  The graphs are 0 to 65 degrees off axis on a asymmetric baffle with sharp edges at 1 meter.
    GowaWolfrjj45PWRRYDD1PP1NThumperTomkennykDanPNicholas_23Bryan@MACand 1 other.
  • Yeah I was really surprised how thin the aluminum face plates are on my DA32.
  • According to the spec sheet they are steel faceplates.
  • You may want to rethink removing the faceplates.  The dome is glued to the subplate and the glue squeeze out sticks to the face plate.  As you pry the faceplate from the sub plate the edge of the dome fabric can also lift off of the subplate. There are a few sections of the dome I had to glue back on.
    My faceplate were scratched dented so I felt I had no choice.  The faceplates are steel.
    GowaWolfNicholas_23JasonP
  • The one thing that pissed me off about them was this issue.
  • Put everything back together.  Impedance sweep is identical.  I think I got lucky.
    PWRRYDGowakennykJasonP
  • What are you going to mate them with?
  • Rival woofers, I'm thinking the same as Dan.
    Bryan@MACJasonP
  • Here what I’m mating mine with crossed so far @ 2.2k 3rd order no att circuit. Nice sound tweeter.
    R-CarpenterGowajr@macS7910kennykJasonP
