When you modded your B452 with the ND28 tweeter - did you have to make any additional sawdust for the tweeter to drop in? I am considering several options (I need speakers for my desk at work), but want to be able to tear one out in a short period of time.
Also - woofer cutout a pretty standard 4"? I have the buyout poly woofers that will probably work, but might buy something else if it will drop in.
Hey JR I'm traveling so I'm a bit slow lately. Any who, the ND28 is smaller than the existing tweeter. It's so small I filled in the tweeter hole. The woofer hole is tight for the CF120, but It's a cast frame. See attached.
I've got some 4 inch stamped frame TBs that looks closer and they can use the existing B452 tweeter.
If you have a decent 4 incher the existing tweeter would work as a super tweeter from maybe 4K. I've attached the FRD
BTW, I'm not a big fan of the ND28 crossed low @ 2K, It sounds much better over 2.5.
I can bring it to Iowa if you want to here it.
Thanks for the legwork on these, John - I have had a pair in my cart for months and months now.
I've got another pair as mentioned above I'm moding and I also picked up a pair of B652(?) for $10 at the tent sale.
